Zoom R16 - How to record the send return effect live?
voltear
Post by voltear » Sun Feb 02, 2020 5:59 am
Would someone please tell me, on the Zoom R16, how do you record the 'send return' effect directly without having to first record a track then go through the mixdown / master process?
I would like to immediately record a synth to a stereo track using an insert effect, which I can do, but also with the wet reverb and a second delay send return effect.
I've spent hours trying to figure this out by reading the manual, exploring every menu and googling endlessly but I'm lost. In fact I think it can't be done but I just find that a bit hard to believe.
leeski
Re: Zoom R16 - How to record the send return effect live?
Post by leeski » Sun Feb 02, 2020 6:38 am
you've inserted the synth channel so that is how it gonna be....
Synth + Inserted FX = channel 1&2
Wet Reverb = channel 3&4
Wet delay = Channel 4&5
«:::A:::» «:::W:::» «:::E:::» «:::S:::» «:::O:::» «:::M:::» «:::E:::»
voltear
Post by voltear » Sun Feb 02, 2020 3:37 pm
Thanks leeski, but I'm afraid that makes no sense to me; you'll need to be way more explicit.
leeski
Post by leeski » Sun Feb 02, 2020 5:04 pm
When you insert on a mixer it usually compressors or eq, these will be permanently on that channel. So you can't record them separate.
I think thats right.
Any way good luck with it.
Mr_Sulcus
Post by Mr_Sulcus » Wed Feb 05, 2020 12:43 pm
As I understand it, you can't record like that because the send/return buses are virtual channels into the master, and the R16 doesn't allow recording to the master track and the individual tracks (including these virtual ones) simultaneously. This was possible on the R8 and I suspect is possible on the R24 as they seem to combine the best of the smaller models.
It was a shock to me that it works this way as I was used to the 8 as a live recorder/tape bank, but needed more inputs.
leeski
Post by leeski » Thu Feb 06, 2020 3:57 am
:oops: :yay:
