Post
by mdoudoroff » Thu Jul 23, 2020 8:25 am
It appears the Komplex was recently discontinued by Koma. Having used the sequencer for the better part of three years, I have a few notes to share in post mortem:
- my single biggest complaint about the Komplex is that it has no lid; for an expensive device with so many easily-damaged, dust-accumulating components, it really deserves a lid to protect it when not in use and when transporting it
- my second biggest complaint about the Komplex is that, despite the per-step buttons, there’s no way to directly select/activate a step; consequently, tuning up a pitch sequence can be an annoying process; the best workaround is to start the sequencer, set the length to 1, and use SSP to de facto activate an individual step
- I have never thought of a single reason I‘d want to use the CV recorder
- maybe a dozen times in three years, one (any) of the sequencers did not power up right, and either became unresponsive or otherwise behaved erratically (cycling the power fixes it)
- once in a while, the master play transport doesn’t actually start all four sequencers (this may or may not be related to the above)
- the inconsistent placement of the division knob on the left half versus the right half is a weird design flaw
- while it looks clean, making all the knobs look the same and labeling them with a spindly font means that you will—from time to time—grab the wrong knob
- the ratcheting capability of the Komplex is amazing, but anything more than four ratchets is—in my experience—not that useful, so it might have been more valuable to offer a variety of ratchet patterns rather than the ability to ratchet up to 16 times
- I have never used the MIDI facilities of the Komplex, so I cannot comment on them
- I updated the firmware twice, and never had any difficulty doing so
- Komplex is large, but it’s also 0 hp, which means it doesn’t carry the "hidden" cost of consuming rack space. Its size makes it quite comfortable to use.
- Komplex is expensive, but not compared to buying four modular sequencers with comparable functionality
The Komplex remains a splendidly immediate sequencer. Exemplary, really. While there are other immediate analog-style sequencers around, the thoughtful Numerology-inspired cross-modulation design truly distinguishes it.
