Eurorack & pedal Distortion : Strakal Brulu
- Thonk Support
- aka Monobass
I knew I would have to own one of these after Os from Expert Sleepers set up his rig next to me at the last Brighton Modular Meet and cranked his Strakal till it squealed.
I've only spent an hour in total with it so far but its fantastic!
I really like the effect you get with a low input, the way it starves.
Also though it has a lovely thickening effect when used with subtlety, it gave my SynthTech e350 some great rasp.
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
AS of October 2020 this account which used to go by the name of Monobass is now manned by various staff at Thonk.
I just got a V2 pedal and I really like it. Thanks for making it. Been lusting for ages!
Is the pedal also okay with modular levels?
What is the safe/effective CV range?
Richard
Richard
Bastard Science Vol.1 and 2 (Hordik, Buchla, Serge, EMS, Oberheim) https://soundanatomy.bandcamp.com/album ... ence-vol-1
https://soundanatomy.bandcamp.com/album ... ence-vol-2
Tales from the Voodoo Box (EMS Synthi A solos) https://soundanatomy.bandcamp.com/album ... ynthesiser
Richard Scott - Several Circles https://cuspeditions.bandcamp.com/album ... al-circles
i'm glad you like it !
it is ok to use it with modular levels, and cv control less than 10v
the cv response is not very linear so you don't have to feed it full 0-10v for entire range.
FX & Modules / http://www.touellskouarn.fr
thanks
settling in with his new buddies
CV output is going from the Blippoo to the Strakal via a mult
this setup actually creates a strange problem: if the CV input is engaged then the mute switch I have between the Blippoo and Strakal audio path doesn't quite work properly. Even when muted the signal still seems to get through to the Strakal? Never had anything quite like that before. Quite odd. It could be that even a very small amount of leak that somehow gets past the mute switch becomes as loud as the unmuted signal. This only happens when the CV input is used.
Unrelated switch question: the bypass switch on the Strakal is so hard and loud that I'm afraid I simply must replace it with a silent one. I assume a switch is a switch is a switch, but is there any specification I need to know before sourcing a more silent replacement? Or could you even point me to one?
Yes really Strange... don't know for now how this can happenrichard wrote: Quite odd. It could be that even a very small amount of leak that somehow gets past the mute switch becomes as loud as the unmuted signal. This only happens when the CV input is used.
this is a 3pdt switch wired as true bypass.richard wrote:Unrelated switch question: the bypass switch on the Strakal is so hard and loud that I'm afraid I simply must replace it with a silent one. I assume a switch is a switch is a switch, but is there any specification I need to know before sourcing a more silent replacement? Or could you even point me to one?
thanks it seems I need to keep the input level down to below 5%. Strange because I am inputting line levels not modular.
Sounds insane though, I'm sure it is just a matter of finding the exact setting for my setup
Report back: I tracked the leakage and noise problems to a bad moulded cable which was turning everything a bit a microphonic. Changed that cable and Everything is sweet here now.
you don't happen to know of a "silent" 3pdt switch do you? This one is really not suiting me
unfortunately the silent switches i know, are not 3pdt, and use relays or fet for true bypass. But it is possible to change for a silent solution with the expense of an additional circuit.
here is an exemple
http://www.muzique.com/news/relay-bypass-revised/
This is a 1″ x 1″ pc board which holds an AVR microprocessor that is controlling a latching DPDT relay. The LED indicator on the pedal is also driven by the micro. The soft-touch momentary switches that are shown several posts below were bought for this project.
You can use the pcb to build a new pedal, or retrofit it into a Boss or Ibanez box to give them true bypass.
Just got a Strakal Brulu the other day. This thing has tons of character. Here's a little demo, lots of manual tweaking going on:
[soundcloud url="https://api.soundcloud.com/tracks/135152140" params="auto_play=false&hide_related=false&visual=true" width="100%" height="450" iframe="false" /]
- modestnikov
- Learning to Wiggle
- modestnikov
Is it problem? Or is it normal situation?
https://www.dropbox.com/s/sqgk3j8zqaddt ... 8.mp4?dl=0
Hi modestnikov !
i think it is pretty normal...
output depends very on what you feed in, and the feedback is touchy too you can have te same setting and the output sounding will be very very different if the input source varies a little in gain...
also , the is a trim on the back, you could check with a multimeter if you have -6V on R1, this biases the transistor and can change a little over time or temperature. this will modify the gain/fuzz/feedback point also and could make the distortion sound grainy or thin
this module is kind of chaotic and even if i matched myself all the transistors every module sounds different from each others
Re: Eurorack & pedal Distortion : Strakal Brulu
Hi everyone,
I just bought a Strakal Brulu, DIY edition, already assembled.
I noticed that the fuzz knob has no effect on the sound (at whatever settings), and patching CV in (bipolar LFO) has no effect either (regardless the position of the fuzz knob).
When the cable that carries a CV (let's say a LFO) is halfway patched into the CV input, i get an effect... so, what could be wrong ? I'm sorry but I'm a total noob in electronics :(
The module seems well calibrated (I get screaming feedback past 1' o'clock).
Do you have any idea to fix this ?
Thanks a lot in advance !!
