The most valuable 4hp money can buy! soundmachines LS1
Support and discussion for soundmachines products.
Moderators: Kent, soundmachines
Paranormal Patroler
Post by Paranormal Patroler » Wed May 15, 2013 11:12 am
Can't we have red as the first bunch? :razz:
morphic
Post by morphic » Wed May 15, 2013 5:06 pm
release date? :hmm:
My Mind is a Tangled Knot I Can No Longer Untie
slovo
Care Bear of Fury
Post by slovo » Wed May 15, 2013 5:12 pm
*placing this here to remind myself to buy a skiff-full of these*
:omg:
(ignatius) "it's like Point Break meets Schindler's List"
AIRSEA - Creepy noises to protest air pollution
lessavyfav
Post by lessavyfav » Wed May 15, 2013 5:35 pm
Blacklight!
I'm Tim and I'm excited for modular synthesis! :nana:
soundmachines
Post by soundmachines » Thu May 16, 2013 7:21 am
Ok I understand...
We will also sell packs of leds.... :)
soundmachines
we play synthesizers !
www.sound-machines.it
morphic
Post by morphic » Fri Jun 14, 2013 6:07 pm
news on release :hmm:
morphic
Post by morphic » Sun Jun 23, 2013 5:00 pm
:bump: on news?
soundmachines
Post by soundmachines » Mon Jun 24, 2013 2:18 am
Components will be shipped tomorrow to the manufacturer.
We hope to have 120 of those in stock in 10 days!
Last news: the LEDS will be RED!
Cheers!
soundmachines
morphic
Post by morphic » Mon Jun 24, 2013 9:36 am
Damn wanted blue :hihi:
skullservant
Caveman Dirgescapes //
Post by skullservant » Mon Jun 24, 2013 11:36 pm
Looking forward to the release! Great to see this come to life as well
DIRGE // PUTRID AROMATICS
putridaromatics.bandcamp.com
morphic
Post by morphic » Thu Jul 11, 2013 3:38 pm
ordered one today :party:
soundmachines
Post by soundmachines » Thu Jul 11, 2013 3:45 pm
morphic wrote:ordered one today :party:
:hail:
soundmachines
bj_gzp
Post by bj_gzp » Mon Jul 15, 2013 4:37 pm
I received the LS1 today. :sb:
They work as advertised, and jesus, the LEDs are bright.
I have the pulp logic ribbon next to it, and there is no comparison, LS1 is like alien tech compared to a normal ribbon. It's so smooth and fluid. :bacon:
Only downside are the mounting holes, i use M3 strips and have trouble mounting them. Be it 1st or 2nd hole from the edge, it doesn't fit.
Gladly 84HP are 85HP in reality so i can fit them using the spare HP, resulting in gaps of 0.5 HP. :sadbanana:
waveglider
Post by waveglider » Mon Jul 15, 2013 5:00 pm
I can't wait for these to become available in the US! :hyper:
haesslich
Post by haesslich » Tue Jul 16, 2013 11:53 am
bj_gzp wrote:I received the LS1 today. :sb:
I had exactly the same thoughts: It's the second brightest module I own, right after the 4ms PEG. Looks epic! But might be troublesome in a live situation.
And the same issue with the rails:
I also use M3 strips (doepfer and acidlab cases), and the drilling seems to be exactly in the middle between two hole positions.
maybe one can widen the drilling with a dremel - if no circuit path is next to the hole.
apart from that: the looping function is really cool. you can even tap sloppy rhythms ;-) i didn't try the gate-in mode yet though.
seriously concerned about sound
bj_gzp
Post by bj_gzp » Tue Jul 16, 2013 12:07 pm
haesslich wrote:I had exactly the same thoughts: It's the second brightest module I own, right after the 4ms PEG. Looks epic! But might be troublesome in a live situation.
This is exactly what Davide suggested me this morning by email.
I have an idea, as the panel is FR4 you can easily file off some material. There are no traces in that part of the pcb...
I'll make it on mine and then send you some pics!
Didn't get the pics yet, but i told him it's currently not an urgent issuefor me , as i have that spare HP in my skiff.
haesslich
Post by haesslich » Tue Jul 16, 2013 12:13 pm
bj_gzp wrote: This is exactly what Davide suggested me this morning by email.
thanks for the info, that's good to know. i'll try this once HP are an issue again. i've lots of space at the moment, since one bigger module is out for repair.
haesslich
Post by haesslich » Tue Jul 16, 2013 12:20 pm
double post.
however, still blown. so much fun. i guess i'll sell the koma commander now, which i never enjoyed really that much.
bj_gzp
Post by bj_gzp » Tue Jul 16, 2013 12:28 pm
yes the looper is fun, highly flexible performance tool. Makes the LFO's a bit redundant in a compact system.
I have 4 of them next to each other, i nearly have to wear sunglasses in the dark
I look forward getting a LP1 as well. Two parameters at the fingertip and loopable as well :sb:
soundmachines
Post by soundmachines » Tue Jul 16, 2013 12:29 pm
Hello everyone!
Thanks for loving the LS1 !!!!
I did not took the pics of the filed PCB, I should send it tomorrow morning, but I confirm that with a small file you can easily remove 1.5mm of PCB without compromising the module. I don't advise using a dremel unless you have a very firm hand!
Instead of placing the hole centered on the 7.5mm that the standard tells, we put the hole to the left of 7,5mm :bang:
soundmachines
soundmachines
Post by soundmachines » Tue Jul 16, 2013 12:34 pm
bj_gzp wrote:yes the looper is fun, highly flexible performance tool. Makes the LFO's a bit redundant in a compact system.
Ahem..... with the LP1 you have THREE parameters at your fingertip...
X, Y and PRESSURE :nana:
I am playing right now with TWO LP1 and you can basically control a very complex patch with your two hands in a very limited space..... I think that LS1+LP1 could fulfill a 105HP skiff for FREAKING control!
soundmachines
haesslich
Post by haesslich » Tue Jul 16, 2013 1:24 pm
soundmachines wrote: I did not took the pics of the filed PCB, I should send it tomorrow morning, but I confirm that with a small file you can easily remove 1.5mm of PCB without compromising the module. I don't advise using a dremel unless you have a very firm hand!
i'll get me a small file then first. :tu:
soundmachines
Post by soundmachines » Wed Jul 17, 2013 3:23 am
Ok guys, for the people low on HP space I made some pictures this morning.
To solve the hole positioning quirk you have to use a 'rat tail' file like the one in the pic:
You have to file about 1.5mm of PCB. In that zone there are NO traces so just be careful to not over-thin the external part of the PCB (tough FR4 is sturdy enough to resist to some degree of abuse). This is the result:
And this is the final result. I put the module near to a Doepfer one that IS the standard...
Cheers!
Davide
soundmachines
bj_gzp
Post by bj_gzp » Wed Jul 17, 2013 3:27 am
:tu: thanks Davide for the detailed instructions.
Wasn't aware the LP1 senses the pressure as well. pure dope it will be :bacon:
haesslich
Post by haesslich » Wed Jul 17, 2013 3:48 am
looks really like a dremel is not needed.
:hail:
Return to “soundmachines”
