Mutant Clap DIY Calibration Stupid Question
Moderators: Kent, hexinverter
toneburst
Post by toneburst » Mon Mar 09, 2015 4:21 pm
Sorry, probably a stupid question, but I'm trying to calibrate my Mutant Clap. I'm at Step 1 (Calibrating offset null) from the build tips doc. Where should I put the second probe from my multimeter, in order to test the voltage at the test point?
a|x
Sone_brian
Post by Sone_brian » Mon Mar 09, 2015 8:54 pm
Would like to know this myself as my kits are in route and I thought the same thing..
toneburst
Post by toneburst » Fri Mar 13, 2015 5:26 pm
You can use the lower pin of the Default Accent selector header, I discovered. I'd been trying to use the middle pin of the same header, but that's not connected to ground, as I had assumed.
My voltmeter isn't very accurate in the mV range. Hopefully yours will be better.
a|x
acidict
Post by acidict » Mon Mar 16, 2015 12:37 pm
you can also clip a crocodile on a ground lead of a socket or the LM7805 ground, then you got a free hand!
toneburst
Post by toneburst » Tue Mar 17, 2015 2:02 pm
Thanks for the tips, guys. I ended up fine-tuning by ear, as my voltmeter isn't very accurate. I think I got it to work though.
a|x
paperwork
Post by paperwork » Sat Apr 04, 2015 10:14 pm
I'm struggling with this step now myself. When I turn the "offset null" trimpot, I'm only getting between about 3.6v and 4.8v on my multimeter, and that's only in the very far counter-clockwise direction; most of the range just has the value stuck around 4.8v. I've checked the boards for soldering mistakes & don't see any. The manual says this should be -100mv, so I'm way off.
Toneburst, how do you tune this setting "by ear"? What are you listening for?
I'm assuming there's something wrong with my build, since those testing values are so far off. Any ideas? I may try replacing ICs next, I guess?
EDIT: My LM13700 was plugged in backwards :bang: -- it seems to be toast. ordering another one now; I should have known to keep more than one on hand!
skylab001
Post by skylab001 » Fri Dec 18, 2015 12:14 pm
Can anybody tell me if there is a 'Factory' setting for the Reverb volume? Just received a Mutant Claps, it looks like it is a DIY build, very nice at that. It all works fine, sounds good, but the reverb seems to be a little hot. I was just curious if there was a particular setting like 4v p-p or something. Knowing this is based on a 909 I looked at the 909 service manual but didn't see anything, so this might just be akin to the mutant clap circuit.
batch
Post by batch » Mon Aug 01, 2016 12:11 am
So I had a lot of trouble calibrating my mutant clap. Multiple attempts and never got anywhere. However tonight I finally got it dialed in and it's a different module. Way to better. Anyway, thought sharing my experience might help someone else, so here goes.
1. Did offset first
2. Module was turned on (took me awhile to realize this)
3. Rev Dec was fully up as it says
4. Black was connected to the lower accent jumper (thank you for that suggestion!!)
5. I couldn't get to -100, closest was either -120 or -80. Ended up going with -120
Then I moved on to the rev volume. This was super frustrating. With the rev dec at half way and the sustain at zero I had no noise. Also had everything else turned off. Anyway, after a while of going one way or another I finally gave up, couldn't hear anything (whereas previously I just had really loud noise). I finally gave the offset a little turn counter clockwise (maybe a quarter turn) and voila, got it!!
So advice is this a) don't give up, the module is so much better once dialed in b) get the offset as close as you can c) get the other trimmer close to the middle, the. Finally d) readjust the offset trimmer.
Hope this helps others
batch
Post by batch » Mon Aug 01, 2016 12:12 am
Oh - when I started my offset was reading 12V
Delabelle
Hexinvertor Mutant Clap
Post by Delabelle » Wed Oct 12, 2016 10:53 pm
Hello everybody,
I can't seem to have any reverb at all on my diy mutant clap module.
Anybody had the same problem?
G
