mutant hot glue compression problem
Moderators: Kent, hexinverter
bruital
Post by bruital » Wed Dec 16, 2015 11:18 am
hello
i just finish to built my mutant hot glue!
every thing is ok but compression is out:
i have calibrate it but the comp made a very bad distorsion with a gain of 0 to +20db and after nothing!!!
have you an idea?
thanks
bruital
Post by bruital » Tue Dec 22, 2015 5:47 am
so i have a problem with the comp : the sound distort a lot with a little gain, and shut down with a middle gain (like too much of gain)
i check the sound on the that 4301, the sound distort at the output of the VCA ( pin 13).
on the pin EC- (16) of the that 4301, i mesure 0v with 0 gain and -2.3v at max gain.
the sound stop at -0.59V.
are this values normal or it's to big???
magiseoane
I have the same problem....
Post by magiseoane » Thu Feb 11, 2016 3:58 am
:despair: :despair: :despair: :despair: :despair:
