Mutant Glue compressor speed mod?
Moderators: Kent, hexinverter
trimix
Post by trimix » Sun Jan 03, 2016 1:38 pm
Hey guys - just building a Mutant Hot Glue, modding for installation as MOTM.
There is a jumper connect that determines the compressor speed, setting hi,med,low. I KNOW I would want to change this setting frequently, and I think this is just begging for a switch on the panel....but I don't know enough about circuit bending to safely go ahead. Can anyone help? :despair:
I'm thinking a toggle, three position [on-on-on] would work, so...is that a DP3T ? Is it safe to simply run leads to the jumper locations?
Hazium
Post by Hazium » Fri Jan 15, 2016 6:36 pm
I would love to know the answer to this also. Great idea!
orlog24
Post by orlog24 » Thu Mar 24, 2016 11:57 pm
Im pretty sure thats all you need to do. Definitely safe.
Basically you are just replacing the physical removal and placing of the jumper with a switch instead.
