DIY Mutant clap noise floor
Moderators: Kent, hexinverter
Xssory
Post by Xssory » Fri Jul 29, 2016 8:50 pm
I've been using my DIY clap for a while now, and I've noticed that it's noise floor seems very high compared to my factory built Mutant Hi Hats. Particularly when I turn the drive up the hiss is very prominent. Did I do something wrong in assembly? Just curious if anyone has a factory built module that can chime in on this or someone else who has encountered the same issue
polycorn
Post by polycorn » Thu Oct 20, 2016 9:58 am
Found your post and this one: viewtopic.php?t=135569&sid=540486cd6045 ... f57f32da76
While searching info on this problem. No solution yet....
ilya.n
Post by ilya.n » Tue Nov 29, 2016 12:17 am
I got the same issue. It sounds like noise oscillator is leaking into the output. It seems to be an inherent design issue and I haven't seen anyone fixed it yet. Just keep you Drive level at low level or run the clap through and additional vca.
ege.gonul
Post by ege.gonul » Thu Jun 01, 2017 10:30 am
Its just classic Hexinvert fault. He designs it for SMD soldering and makes a through hole DIY option and as a consequence you got lots of floor noise. Glad that Hexinverter is moving out DIY.
