Grounding CL to other synths
home of post-70s electronics
Moderators: Kent, bartlebooth
woVERTICES
Post by woVERTICES » Sun Jan 10, 2021 12:40 pm
I'm concerned about sending CV's from my Coco to an Studio Electronics Boomstar CV in. If my Lowgain format jumbler is grounded to the Coco, will the 3.5 mm cables to the Boomstar infant be grounded?
Best,
John
Jonny
Re: Grounding CL to other synths
Post by Jonny » Mon Jan 11, 2021 8:59 am
If you are attaching the ground cable to the one on the side of the format jumbler box, you should be good. The ground is then connected to the sleeve of the patch 1/8" cable.
Return to “Ciat-Lonbarde”
