New IFM module? Dunst
home of post-70s electronics
Moderators: Kent, bartlebooth
Post by 333 » Sun Aug 16, 2015 7:12 am
paperwork
Thank you! Quite an interesting range of noise :sb:
Nofrenchtests
Post by Nofrenchtests » Mon Aug 17, 2015 2:31 pm
thanks paperwork, definitely sold me on it.
:cloud:
damase
Post by damase » Tue Aug 18, 2015 6:26 pm
what an excellent demo. cant wait to get one. and yes soundcloud definitely destroys high end you are not mistaken.
yghartsyrt
permanent entropy
Post by yghartsyrt » Thu Aug 20, 2015 2:30 am
ordered!
kozepz
Post by kozepz » Thu Aug 20, 2015 10:12 am
Great module, very diverse noises!
Thanks for the soundclips!
reppiks
Obscure Intergalactic Destroyers!
Post by reppiks » Tue Dec 19, 2017 12:38 am
Anyone know what the trimmer on the back of Dunst is for?
rodrigo
Post by rodrigo » Tue Dec 19, 2017 9:53 am
reppiks wrote:Anyone know what the trimmer on the back of Dunst is for?
I was curious of that myself, especially noticing how quiet the noise output is.
reppiks
Post by reppiks » Wed Dec 27, 2017 10:02 pm
So I adjusted the trimmer while listening to the different outputs, and it just affects the maximum density of one of the BNOICE outputs, so I just turned it up to max to give the widest range. Other outputs not affected, and nothing to do with output levels (I use a Befaco InAmp to boost outputs when needed).
pugix
Post by pugix » Sat Jan 27, 2018 10:50 am
I just picked up a used Dunst and while checking it out also noticed the very low amplitude of the noise output (lower right). I'll be putting it on the scope today and might write up something about what I find.
So far it looks like the top section is the more useful, with the variable ramp being useable as an envelope, and the pulse output works great as a random trigger.
Richard
http://www.pugix.com
subliminal drew
Post by subliminal drew » Wed Jan 31, 2018 1:29 pm
I’m relieved to hear to see other folks are having the same low-output experience as me. I also bought one used and was trying to figure getting the most from the BNOICE outputs. Looked real weird on my cheap ’scope; no insights gained.
I guess I’ll have to try feeding it more input voltages and see how the organism reacts.
rodrigo
Post by rodrigo » Fri Feb 02, 2018 10:40 am
From the short time I played with it on a scope, it appeared to be white noise that was DC offset, but then clamped/limited to 0v to 5v, so if you offset negatively, only the little bits at the top of the noise come through, but as a result it's quieter.
The loudest it got was offsetting everything up, so the whole noise signal wasn't clamped, but that was still more or less limited to half volume.
Bomauch
Post by Bomauch » Sat May 05, 2018 2:20 pm
Can someone help me find the trimmer on the back of Dunst? I just looked today and din't find it. :(
pugix
Post by pugix » Sat May 05, 2018 5:02 pm
Some don't have a trimmer. Mine doesn't.
Richard
Bomauch
Post by Bomauch » Sat May 05, 2018 6:32 pm
Oh dang! The output is definitely low for me as well- but I’ll just have to make it work with what I’ve got!
Kingnimrod
Post by Kingnimrod » Mon May 07, 2018 9:01 am
best way to deal with the noise is to get a line amp or a VCA with boost like the intellijel quad VCA. You could also get aggressive with the FSS Gristleizer modules. The preamp offers 40db of gain plus a boost switch and "bite" control, in addition to some EQ and other stuff.
rodrigo
Post by rodrigo » Sat May 12, 2018 8:59 am
Finally got around to "calibrating" mine (basically doing what @reppiks did). It's a shame the Hiss output is so quiet though.
pugix wrote: I just picked up a used Dunst and while checking it out also noticed the very low amplitude of the noise output (lower right). I'll be putting it on the scope today and might write up something about what I find.
I wonder if you got anywhere meaningful with scoping it out?
rodrigo
Post by rodrigo » Mon Jun 04, 2018 5:38 pm
This may be a naive question, but has anyone looked at the circuit/schematic with an eye on having louder output?
jvt
Post by jvt » Mon May 27, 2019 7:10 am
Is there any kind of mod that can be done to raise the "crackle" output for a Dunst that doesn't have the trimmer? Mine is practically silent.
Ras Thavas
Post by Ras Thavas » Tue May 28, 2019 6:43 pm
jvt wrote:Is there any kind of mod that can be done to raise the "crackle" output for a Dunst that doesn't have the trimmer? Mine is practically silent.
That's a big "ditto" here as well...
rodrigo
Post by rodrigo » Fri May 31, 2019 4:14 am
The trimmer doesn't effect the output level of that, but a +1 here as well for a mod to raise the output level.
ClausF
Post by ClausF » Fri May 31, 2019 5:55 am
rodrigo wrote:The trimmer doesn't effect the output level of that, but a +1 here as well for a mod to raise the output level.
Yes. and as long as we don't have this two Doepfer A-183-3 would do the Job. Lot of rack space, I would perfer a smaller with two amplifiers...
jimmie
Post by jimmie » Fri May 31, 2019 10:26 pm
I'm wondering if there's some intention for the design. Do you people find some effective use of current state?
timoka
Post by timoka » Sun Jun 02, 2019 1:33 pm
http://soundcloud.com/uzala/dunst-pings
both sides of dunst ping an mmf-1 and crossmodulate themselves.
mortal3
Post by mortal3 » Mon Jun 03, 2019 12:35 am
Deleted.
ookrsia
Re:
Post by ookrsia » Fri Feb 14, 2020 6:56 am
paperwork wrote:
Sat Aug 15, 2015 4:06 pm
Here's an audio demo:
https://soundcloud.com/paperwwwork/dunst-demo
Just wanna say that many times I've listened to this demo whenever I think about potentially getting a Dunst. Even though it is very simple It is still the most illustrative demo around. So thanks! Not all heroes wear capes! (I'm assuming you dont use capes.)
Return to “Ciat-Lonbarde”
