Plumbutter 2 quick start
home of post-70s electronics
Moderators: Kent, bartlebooth
0netwo0netwo
Re: Plumbutter 2 quick start
Post by 0netwo0netwo » Tue Jan 28, 2020 9:32 pm
timeforest - "starting to dive into crosspatching PB and CQ- ive got the grounds connected. im a bit nevrous lol - i can really patch anything up? nothings gonna blow up anything right?"
just your mind :hyper:
timeforest
Post by timeforest » Tue Jan 28, 2020 10:15 pm
hehe fair enough. but seriously like- can i, say, patch an orange rollz to flip and skip? or the ultrasound output to a green petal banana? or the iron cross to an avdog green banana? anything goes?
timeforest
Post by timeforest » Wed Jan 29, 2020 12:08 am
also can anyone help me make sense of all the blue verso/inverso jacks next to mwrs. i’m not sure what utilities they serve or how to patch with them and can’t find any info
0netwo0netwo
Post by 0netwo0netwo » Wed Jan 29, 2020 12:46 am
they just make it speed up or slow down i believe
sungja
Post by sungja » Wed Jan 29, 2020 5:08 am
Blue bananas next to the mwrs is cv for the mixer part. Why not just try out stuff and find out??
timeforest
Post by timeforest » Wed Jan 29, 2020 6:47 am
hehe i am i just havent noticed those blue bananas having a noticeable effect on any patches
sungja
Post by sungja » Wed Jan 29, 2020 6:05 pm
Those blue bananas for the mixer part are great. Very usefull and often overlooked.
timeforest
Post by timeforest » Wed Jan 29, 2020 7:17 pm
ok yeah - figured them out. you’re right what a cool section. like further clocking weirdness for the mixer!
eyeiaye
Post by eyeiaye » Sat Feb 01, 2020 10:48 am
What do I use the ground for? Just a bit confused lol
electricanada
Post by electricanada » Sat Feb 01, 2020 10:10 pm
For when you cross-patch two different synths together, such as pb and coco.
jimmie
Post by jimmie » Sun Feb 02, 2020 12:06 am
From the manual:
Special Tips
● The COCOs can already go down to low speeds resulting in
ghostly, ghoulish sounds. To take them even lower down to
about 1 Hertz (!), follow this recipe: plug the ground cord,
banana plug, into the ground outlet on the back, a banana
jack. Now connect the alligator clip which represents ground
to the SP.AF pin of your desired COCO. This is a "zero
reference" which makes the AFFEC knob into a secondary
SPEED knob, allowing you to dial super low frequencies.
● The ground cord can be used to ground the player of the
piezo, who may be picking up line noise with his/her
body. All this grounding issue really has to do with when you
use a piezo. The balanced mike input doesn't require it, nor
does the synth input.
:oops:
SonarBk
Post by SonarBk » Wed Feb 05, 2020 8:27 pm
Following and just want to say thank you to all for this thread. It’s really helpful.
matheuwatson
Post by matheuwatson » Thu Feb 27, 2020 6:43 pm
This has been really handy, thank you! Does anyone have a function map for the PB 2 similar to the one recently posted for for Coco? Thanks again!
0netwo0netwo
Post by 0netwo0netwo » Thu Feb 27, 2020 10:52 pm
Just noticed last night and hat my 1/8” out on top is not as tight a fit as the 1/8” ins on the bottom. The connection will slide out with less effort than it will with the ones on the bottom. Is this just something normal or should i be concerned and have to send it back to be repaired eventually??
Since i noticed it im kinda freaking out 😟
ignacio
Post by ignacio » Thu Mar 05, 2020 6:40 am
Very helpful. Does use the audio jacks? Still unsure as to what they are for.
x2mirko
Post by x2mirko » Fri Mar 06, 2020 7:15 am
The audio jacks on the front are there to inject signals into different parts of the plumbutter. Not in front of it, but I remember the leftmost sends signals into the Gongue-filters and the rightmost into the deerhorn (so you can control the amplitude of the incoming signal with gestures).
Especially the Gongue is great for sending audio in. It has weird interactions with the incoming audio and generally just sounds great). By now, I use my Plumbutter more with external signals than without.
Yloopz
Post by Yloopz » Fri May 15, 2020 2:04 pm
Oké, question, just got the plum and i like it (got a Coco and tetrax as well) but i have got a question. I understand everything but one thing i dont. Is the gongue right top the same as the left bottom. And in behaviour? I got only noise and feedback from the right top gongue. I put a orange out into the green of the right top, nothing happens. When I put it in the left its working fine. When I use the switch, switching up and down I hear what I think I supposed to hear, but Then silent again. Sometimes when I put the cable in or out the green I hear it as well. So... is that normal behaviour? I tried putting divers signaal in green, purple etc... nothing. Enlighten me please.
My imagination is my inspiration...
Instagram: @jungleofwires
mrbloor
Post by mrbloor » Fri May 15, 2020 2:55 pm
Hi, each gongue is in reverse they are identical. Switches either up or down to get sound, each one has a rate knob which effects the amount of times each one will strike from a pulse. Set both at fastest rate triggered from the same orange rollz & they should sound together.
Yloopz
Post by Yloopz » Fri May 15, 2020 3:12 pm
Oké thanks, i think the green Banana isnt working. I did Some more testing just now and every green Banana is reacting to a pulse, accept for the gongue right top. The purple is working just fine. The audio is working when i use the switch, but when i put a pulse in the green... nothing. Thanks for your feedback, i Will have a look how to repair it
ClausF
Post by ClausF » Fri May 15, 2020 3:48 pm
There's a thread here in the section how to re-solder the PB bananas...
Yloopz
Post by Yloopz » Fri May 15, 2020 4:32 pm
Yes found it. Thanks. I am a soldering noob but I have good contact with a eurorack builder nearby. He knows the Ciat Lonbarde instruments well so he is Going to have a look and do some metering as well. And he is going to learn me soldering because in the future I want to do it myself. It is looking pretty easy by the pictures in the repair thread..
mrbloor
Post by mrbloor » Fri May 15, 2020 8:20 pm
Glad you've sorted it, I've owned 2 plumbutters & it's happened a few times, part of their charm. :-)
0netwo0netwo
Post by 0netwo0netwo » Fri May 15, 2020 11:56 pm
nobody else has shared my experience with the audio jacks?
mrbloor
Post by mrbloor » Sat May 16, 2020 8:07 am
Hi, I don't think it's a concern. I've just got some eurorack & notice a discernible difference between 1/8 connectors, there is probably manufacturing tolerances at play. I don't like 1/8 connectors on music equipment but I suppose the acceptance for these connections has become the norm as devices have become more portable. Any piece of gear with 1/8 connections I've been really careful after a lifetime of re soldering headphone connections on walkman's, yes they can fail but it's a relatively simple fix on something like ciat lonbarde.
Yloopz
Post by Yloopz » Sat May 16, 2020 4:22 pm
I just wat to say that the plum is working fully again. We did a little reflow of the soldering of the green banana. That was it. An easy fix...
Return to “Ciat-Lonbarde”
