what next for c-l?
home of post-70s electronics
Moderators: Kent, bartlebooth
Ras Thavas
Re: Re:
Post by Ras Thavas » Sat Feb 08, 2020 11:04 pm
Yes, thanks, that is a great resource, I regularly check Pugix for new posts. But needing at minimum 2-3 modules for each quantussy cell, multiply that by 5... it gets a little kludgey and cumbersome. Having one large module designed specifically to provide the multiple modulation sources the Quantussy does would be more desirable, IMO at least :)
electricanada wrote:
Sat Feb 08, 2020 8:32 pm
Ras Thavas wrote:
Fri May 17, 2019 7:51 pm
williamjturkel wrote:I'd love to see more IFM modules!
Seconded! Give us the Quantussy as a module
Patch your own: http://pugix.com/synth/eurorack-quantussy-cells/
williamjturkel
Re: what next for c-l?
Post by williamjturkel » Mon Feb 10, 2020 8:41 am
I also patched my own Quantussy (I guess a Triussy because I only had three cells) - the results are cool, but it requires a lot of extra modules and a lot of cable spaghetti for a small case. Since I tend to create self-contained 6U 84hp instruments, I couldn't justify the space.
electricanada
Post by electricanada » Mon Feb 10, 2020 11:19 am
Mutable Stages plus Takaab lfo gets you three cells in 20hp.
timeforest
Post by timeforest » Mon Feb 10, 2020 11:56 am
what’s the relationship of stuber to DDD? am i on the right track in thinkng it is similar but has a “filterbank”-like aspect? does it also use the cores that DDD uses?
williamjturkel
Post by williamjturkel » Wed Feb 19, 2020 11:04 am
I used three Tromsos and two 2hp S+H which totals 19hp. But the configuration required a real mess of stackcables, or adding mults.
Return to “Ciat-Lonbarde”
