Random*Source Serge + C-L?
home of post-70s electronics
Moderators: Kent, bartlebooth
odditymedium
Post by odditymedium » Thu Jul 04, 2019 8:43 am
i wanna try plugging in my friend;s Random*Source Serge to the Plumbutter and the Cocoquantus ... will I blow things up?
I wont be plugging anything into the browns... anything else I should know?
The Grump
Post by The Grump » Wed Jul 10, 2019 6:58 am
Make sure that your grounds are connected.
odditymedium
Post by odditymedium » Wed Jul 10, 2019 8:38 am
so... if the grounds are connected, everything is ok?
also same goes for loudest warning?
the bad producer
Post by the bad producer » Wed Jul 10, 2019 9:03 am
I’ve never used C-L but if it’s okay for *RS* and Serge etc, it’s Ok with mine as same voltages etc
The Grump
Post by The Grump » Tue Jul 16, 2019 1:51 am
The voltages are pretty close, so yeah, you should be fine, with connected grounds.
southphillysynths
Post by southphillysynths » Thu Jul 18, 2019 6:49 am
i've been using a cocobutter with a serge panel, works just fine!
I would just be careful of the browns/oranges of rollz, but even so with connected ground you should be fine.
Dcramer wrote:"Not all who wiggle are lost" :boat:
WHO IS BOZO TEXINO?!?!
Return to “Ciat-Lonbarde”
