'Teleplexer' patch with IFM modules and Mocante
home of post-70s electronics
Moderators: Kent, bartlebooth
williamjturkel
Post by williamjturkel » Sun Nov 17, 2019 10:45 am
I guess this should have been obvious to me, but I recently discovered that if you plug a patch cable into, say, a Sprott input, you can use the tip of the other end to probe the Mocante touch points and get a ridiculous range of possible audio outputs. The Mocante doesn't have to be plugged in to anything else. For added goodness, connect the Mocante's pitch input to one end of a patch cable and use the other end for FM by touching it to Mocante pads at the same time.
jimmie
Post by jimmie » Sun Nov 17, 2019 7:13 pm
Will it work on Tocante, too? I mean I could just try with mine but if it's safe to Tocante..
williamjturkel
Post by williamjturkel » Sun Nov 17, 2019 7:41 pm
Unfortunately I don’t have any C-L gear, so I can’t say.
Return to “Ciat-Lonbarde”
