Ciat-Lonbarde Knob Upgrade?
home of post-70s electronics
Moderators: Kent, bartlebooth
eyeiaye
Post by eyeiaye » Mon Jan 06, 2020 8:33 pm
Loving the Ciat-Lonbarde stuff. But is there a decent knob upgrade? The stock ones are a bit bland for my taste. Would be amazing to have something metal, so it could be as elemental as it sounds!
NeolithicElectrophones
Re: Ciat-Lonbarde Knob Upgrade?
Post by NeolithicElectrophones » Mon Jan 06, 2020 9:36 pm
Find out the shaft type by pulling a knob off, measure the outer diameter and then get to searching for something you would like.
Current favorite knob sources:
https://www.taydaelectronics.com/hardware/knobs.html
https://modularaddict.com/parts/knobs
https://smallbear-electronics.mybigcomm ... m/knobs-1/
If you want metal I've been really digging these lately, great feel and finish plus I think they would look really great with the wooden aesthetic.
https://smallbear-electronics.mybigcomm ... ll-colors/
nangu
Post by nangu » Mon Jan 06, 2020 10:19 pm
I don’t know for sure, but those knobs look like the ones Hexinverter uses. If that’s the case, then they’re D-shaft knobs- but with the pointer aimed in the opposite direction of most other D-shaft knobs.
I’ll check into it and post again when I know more..
nangu
Post by nangu » Tue Jan 07, 2020 2:48 am
Yep, same as Hexinverter knobs- just gray instead of black.
I believe that makes them a ‘Reverse D-shaft’. They’re the opposite of WMD knobs, anyway. WMD is also borderline too short and fits quite loose on this Coco.
Intellijel-style is a bit taller, fits nice, and you can make the pointer aim any way you please. The one in this pic is a ‘Black Small Skirt D - Sifam Plastic Knob’ from here:
https://www.thonk.co.uk/shop/intellijel-black-knobs/
mutierend
Post by mutierend » Tue Jan 07, 2020 10:54 am
Love My Switches has some great knobs.
Post by NeolithicElectrophones » Tue Jan 07, 2020 8:48 pm
Oh damn! Thanks for linking. Totally forgot about Love My switches, great stuff and even better service.
Also to add for OP, I haven't had any issues mounting 1/4" shaft pots with set screws on d shaft knobs, just cut a little piece of stiff card stock or hard poster board to fill the gap and you're good to go. Did it on older NLC projects where due to pot orientation D shafts are upside down and it worked really well.
nangu
Post by nangu » Tue Jan 07, 2020 9:15 pm
The knobs are recessed into the wood so deeply that tightening set screws would likely be impossible.
I suppose one could try to take the wood off, but I’ve never done that to CL stuff. Sounds like a task that’d be worth avoiding..
Post by NeolithicElectrophones » Tue Jan 07, 2020 9:40 pm
Hmm, definitely looks like a hassle. From the last time I fiddled with a cocoquantus I thought there was a little more wiggle room, but I guess not.
Maybe these would work. A bit less diameter( 12.7 vs 14.2) than the Thonk ones linked and it says it has 2 set screws. Wonder how high up the second one is?
https://www.allelectronics.com/item/knb ... aft/1.html
Return to “Ciat-Lonbarde”
