Hello Tenori-On users
Yamaha shut down all support - let this instrument live on here!
Moderators: Kent, ritchiedrums, Paranormal Patroler
Paranormal Patroler
Post by Paranormal Patroler » Sun Apr 05, 2015 2:37 pm
IR wrote:If you want to control CCs and mess with lots of settings, better get something like a Korg EMX-1 or ESX-1 or Yamaha RM1X, on all those you can remap the knobs to different CC values.
The Draw Mode of the TO is fantastic for making automations for CC's. With the EPP you can rescale the 16X16 grid to cover all 128 values of a CC and it's easy to draw very drastic changes. I do this all the time.
lotri22
Post by lotri22 » Mon Apr 06, 2015 4:06 am
IR wrote:
lotri22 wrote:
Paranormal Patroler wrote:Depends on what it is exactly you're looking for, I can't tell by your description above: trigger Kick=mute Input ???
Let say, I wanna use each layer for triggering one voice on TR8.
CH1 for Kick, if the notes triggers the kick sound,at the same time I want turn the note number to CC value corresponding with the Kick's decay and CC value which opens the input's gate (will make the input duck when Kick is triggered)
CH2 for snare and so on
On the other hand, you could use a Tenori-On to trigger modular drums (with a MIDI to trig module), and simply connect the outputs of the modules to a mixer. You can then mute sounds at the mixer.
TR8 is not as deep as the electribes but I like the UI and the classic sounds,and it's limitations. I have the best fun with it when sequencing with Numerology,playing with polyrhythms and lfoing velocity, CC's….
But tenorion doesn't need computer,is faster,more intuitive and it's structure forces the creativity from different angle. It's just too limited with the simple midi note on/off transfer.
Mr. Pete
Post by Mr. Pete » Thu Apr 09, 2015 8:20 am
I have found Tenori-On SD in small computer shops too dirt cheap so I bought extra but you never need more than one per hardware tenori since you have a computer to back up your data ~ and that data is so tiny I have yet to run out of space on its small capacity SDs
I played with the "i" again and am amazed more people aren't jumping on it
- loads of new features since I last looked beyond more user samples, and color ~ you can now route layers to different iOS synths on your iPad like Animoog ~ but still I far prefer the hardware versions playing the touch screen command L1-5 and R1-5 buttons is really quite awkward on the iPad compared to the real things
IR wrote:I don't own one, but I thought they were interesting so I downloaded the manual. Noticed it needs "vintage" sd cards, I was looking for those in shops a few months ago for my camera, impossible to find in real shops.
You can call me, "PETE"
https://petedako.bandcamp.com/music
@petedako on Twitter/FB/Instagram
rabc
Post by rabc » Sat Jun 27, 2015 8:23 pm
Paranormal Patroler wrote:The TO sends each layer on a different MIDI channel, as you probably already know. Your above requirements are easily addressed via the MIDI Solutions box, but I fail to see where the real-time issue is. You can easily pre-program the EPP to do the above and let it do its thing while you're playing. Do you want to be able to swap between remappings? Can you give me an example of your editable in real-time requirements?
Hi! Just acquired a practically new TNR-O for dirt cheap and want to use it to control my Roland TR8. Found this this thread as been searching high and low for some Tenori-On (hardware) MIDI info!
So... Tenori-on sends each layer on different MIDI Channel? Ok, I was unaware of that! If I wanted to use my TNR-O to control my Roland TR8 (which is default to MIDI Channel 10) similar to this video below, do i just need to set Tenori-On to Layer 10?
I've tried that and still no sounds
any advice would be so appreciated
Paranormal Patroler
Post by Paranormal Patroler » Sun Jun 28, 2015 11:54 am
Have you read the manual? Try using Layer 10 and see if that works. Are you sure TR8 is on MIDI channel 10?
rabc
Post by rabc » Sun Jun 28, 2015 10:12 pm
Paranormal Patroler wrote:Have you read the manual? Try using Layer 10 and see if that works. Are you sure TR8 is on MIDI channel 10?
Yeh thanks for reply @Paranormal Patroler.. I read both manuals.. which are both kinda vague actually and admittidly i am no MIDI guru :\
TR8 MIDI Implementation Chart def says defaults on channel 10
http://cdn.roland.com/assets/media/pdf/ ... _e02_W.pdf
Tenroi MIDI info (page 115 of below) states defaults 1-16
http://download.yamaha.com/api/asset/fi ... t_id=13049
I've discovered Tenori-On layers 1-16 = midi channels 1-16 so I've:
1) changed mine to Layer 10 (seeing TR8 defaults on MIDI Channel 10)
2) connected [MIDI OUT] of Tenori-On into [MIDI IN] of Roland TR8
--> still nothing. Sounds I'm hearing are that of the 'internal instrument' selected for Layer 10.
I have to be missing something so small...
lotri22
Post by lotri22 » Thu Jul 09, 2015 2:16 pm
TR8 voices have dedicated note triggers spread over 1st octave I guess, make sure you are on the Scene 10 on TenorOn (transmits on midi ch 10) ,scale mode is chromatic and then lower the octave on that channel ( everything on tenori)
You have to be in the right octave then you will find which notes triggers the TR8 drum voices
keith_p
Post by keith_p » Sun Aug 09, 2015 5:55 am
Hi all,
Great forum! Glad this exists, stoked to find a bit of community around a brilliant piece of kit that I've only recently pulled out again.
Following on from this discussion, first time posting here, having a similar issue regarding midi.
I'm trying to use the tenori-on to play the Electribe EMX-1.
No worries with the synth parts, they work beautifully, and are a load of fun to play on the tenori-on and manipulate live on the EMX.
Just for kicks, I'd like to be able to play the drum parts as well - but I can't get it to work. On the EMX all drum parts are on one midi channel, default channel 10.
I've tried adjusting the channels (from default 10 to each of the 16 layers) and gone through the Octave as suggested above.
I'm starting to think that I've missed something really basic, and that maybe it can't be done.
Ideally I'd be able to operate in a manner similar to what this chap's done with his 808.
Any direction would be greatly appreciated.
IR
Post by IR » Sun Aug 09, 2015 6:30 am
keith_p wrote:I'm starting to think that I've missed something really basic, and that maybe it can't be done.
lol :lolspew: o.k. maybe not quite that funny
you know you can set the MIDI note numbers for the drum sounds in the EMX, and you should save them after you do, right?
(btw, Korg note numbers are an octave off from other manufacturers)
lotri22
Post by lotri22 » Sun Aug 09, 2015 1:18 pm
keith_p wrote:Hi all,
The scale on Tenori might be not sending the right notes to trigger the drum voices, make sure you are in chromatic scale. I was in this same position, it took me time to find the right buttons for my custom midi to TR77 converter
keith_p
Post by keith_p » Mon Aug 10, 2015 5:22 am
lotri22 Thanks! I'll go through the Octaves again tonight.
IR
don't have a full grasp of midi to tell the truth (as I imagine was obvious). but looking through the Tenori-on manual, and I can't find the notes that I'd want to change it to.
sorry if I'm asking the wrong questions. Just thought it would be cool to hook it up for fun.
keith_p
Post by keith_p » Thu Sep 17, 2015 2:26 am
Just for the record this did turn out to be a quick fix with the Octaves.
In Chromatic scale you need to be on -2 for each layer that you want to use.
Only just got around to rejigging things, but stoked to get this working. Such an underrated machine in my opinion.
XPump
tenori-on not goings on - anyone ?
Post by XPump » Sun May 14, 2017 12:31 pm
Spent and afternoon w/o success attempting to get the my Tenori connected thru my Encore Expressionist which I thought would be a snap but I found the the Tenori is only sending all its midi via its Layer 1 to Midi Channel 1 .
I finally used a Mutible CV-Pal to monitor the "-out-" and regardless of what Layers or layers and Blocks set the Tenori to its data input on each layer gets summed with Midi Channel 1 and its sent on layer 1 only .
I must be missing some setting on the Tenori as all the docs state exact layer correlates to the Midi Channel
- Ive looked at all the settings on the Tenori for a few hrs now and I no grok it -- Can someone point me to how I can configure the below ?
Midi Chan#1 <= Tenori Layer 1
Midi Chan#2 <= Tenori Layer 2
Midi Chan#3 <= Tenori Layer 3
Paranormal Patroler
Post by Paranormal Patroler » Sun May 14, 2017 2:01 pm
You can't. Each layer sends to a specific MIDI channel.
XPump
Post by XPump » Mon May 15, 2017 12:44 am
thx for the reply - I'm still confused :bang:-
My understanding was, as Paranormal Patroler stated: "Each layer sends to a specific MIDI channel."
--is that specific channel only 'one' channel then?
A lot of the demo vids sound like there are fully independent voice threads per layer but my experience is each layer is sending thru only one channel.
When i input patterns on Layers 1,2,3 and 4 - all the events appear output only Midi channel 1
..what I thought would happen was :
the pattern on Layer 1 would be on Midi 1
the pattern on Layer 2 would be on Midi 2
the pattern on Layer 3 would be on Midi 3
As all the events are summed out on the one channel notes from the (4) layers "compete" and some are dropped ... (i guess depending on whatever rule of precedence is being applied.)
.. I'm hoping I missed some setting to tweak to have each layer perform independently as multiple sequences and not just a summation of the layers
Paranormal Patroler
Post by Paranormal Patroler » Mon May 15, 2017 7:41 am
Each layer sends to one MIDI channel, which is the same as the layer number. So Layer 1 will send out on MIDI channel 1, Layer 2 on MIDI channel 2, etc.
There is no way to change this, if I remember correctly. I'm not sure what the situation is with your device. What you can do is engage Advanced Mode where you can assign different modes to each layer, so that you don't have to have a specific mode on a specific MIDI channel.
I think there is a thread about Advanced Mode here, but I don't recall how to engage it.
XPump
Advance Mode
Post by XPump » Mon May 15, 2017 11:39 pm
I dug around thru the Tenori posts and found this info:
darenager wrote:
I also discovered that you can reassign the layers to whatever mode you want, which does make it more useful, you have to hold down L1 and L5 whilst powering up to unlock this mode, once done it stays set after power down. Why Yamaha chose not to make this the default is beyond me.
When I get some time I will definitely check this out.
Paranormal Patroler
Post by Paranormal Patroler » Tue May 16, 2017 7:11 am
Make sure that you save your settings so that Advanced Mode is always engaged on your device. It's great, you can swap the Mode on each layer which is fantastic! Imagine 16 layers of bounce ....
BobbiPeru
Recording from the Tenori-On
Post by BobbiPeru » Wed May 02, 2018 3:12 pm
You've got your tight little grooves running on the Tenori-On, and then decide you want to record the layers on to different audio tracks... How do you do it?
I ran each layer of each block I needed out to external audio, and then edited those clips into loops, and imported them into my sequencer. Editing consistent loops is tough because some layers do not begin and end "on the one" (so there'd be some silence before or after the audible section). Anyway, the result of layering these same loops together on an external multitrack was no where near the tight locked-in groove you'd hear from the Tenori-On itself. The attempt just didn't work.
I see there has been a lot of discussion about midi connections / external devices. How about recording the audio (preferably multi-tracking so you can resequence, add fx etc.)? Any found tools, tips, tricks? I don't think this is addressed in the manuals, documentation, or discussions here. Am I wrong? Am I on a fools errand? Cheers.
hbc
III IV III
Post by hbc » Thu May 17, 2018 8:57 pm
Record the midi from all layers, not the audio, into your DAW. play the midi you’ve recorded back into the tenori-on, and record the audio one layer at a time.
KingVidiot
Post by KingVidiot » Sat Jan 05, 2019 10:07 am
Paranormal Patroler wrote:Not necessarily. I managed to find one from a computer shop very easily a year ago when I got my second unit.
Did you ever connect both TNR-W units and run them in master/slave mode?
It's pretty cool. :-)
Paranormal Patroler
Post by Paranormal Patroler » Wed Feb 13, 2019 3:30 am
I actually used an SND ACME clock to control both of them. The results were amazing!
midenok
Post by midenok » Thu Jun 20, 2019 1:46 am
Hello
Return to “Tenori-On”
