Grid controller for the nw2s::b
Discussion, support, and resources for our noise making modules and kits.
Moderators: Kent, scottwilson
scottwilson
Post by scottwilson » Wed Oct 29, 2014 5:51 am
There's no slave clock yet, but I've been adding simpler 1:1 clocking to a few devices... My first demo video shows the GridTriggerSequencer clocked by a 4ms SCM.
Since you based your code on one of the existing grids, you've got the external clocking in what I see of your code (See the comments in timer()). To make use of it, in your ino file, just add something like:
Code: Select all
GameOfLife* grid = GameOfLife::create(...);
// This tells the device that you want to clock it externally
grid->setClockInput(DIGITAL_IN_D0);
// Don't register it with a clock...
// vclock->registerDevice(grid);
// Instead register it directly with the eventmanager
EventManager::registerDevice(grid);
I've offered to add Mr Darkly as a direct contributor to the repo which will make it pretty easy for anyone who wants to use his code who is already using the 1.1 branch and will make it easy to keep his code up to date with the rest of the capabilities I'm adding over time.
-s
myecholalia
Post by myecholalia » Wed Oct 29, 2014 7:16 am
don't stress yourself over it.
obviously totally fine if you'd just take your time and finish it first as you originally stated.
just getting carried away with the excitement
:hihi: :tu:
a scanner darkly
Post by a scanner darkly » Wed Oct 29, 2014 12:14 pm
scottwilson wrote:There's no slave clock yet, but I've been adding simpler 1:1 clocking to a few devices... My first demo video shows the GridTriggerSequencer clocked by a 4ms SCM.
Code: Select all
-s
Had a quick test this morning before work but didn't seem to work - buttonPressed wasn't getting called and it didn't respond to serial input at all. I'll double check again tonight. Here is my code:
Code: Select all
    grid = GameOfLife::create(DEVICE_GRIDS, 16, 8, true);
    /* Setup a variable clock */
    // Clock* vclock = VariableClock::create(10, 240, DUE_IN_A00, 16);
    // EventManager::registerDevice(vclock);
    grid->setClockInput(DUE_IN_D0);
a scanner darkly
Post by a scanner darkly » Wed Oct 29, 2014 12:21 pm
myecholalia wrote:don't stress yourself over it.
:hihi: :tu:
no worries, I was able to clean it up yesterday :-) also it should work with grids of any size now, and I've added a bit of eye candy for the VB grids - cells get dimmer as they get older now (non VB grids continue working as before).
I'll post to GitHub once I have access to the repo.
scottwilson
Post by scottwilson » Wed Oct 29, 2014 1:04 pm
I'll take a look a bit later. I was over-simplifying a bit, and there may be a little bit more code that needs to be in the timer() function that may have gone missing if you didn't think you needed it at the time. Probably not much tho. Should be quick once I get a chance.
And you have been added to the repo!
s
a scanner darkly
Post by a scanner darkly » Wed Oct 29, 2014 2:25 pm
Thanks Scott, I'll take a look as well tonight, could be that I removed some stuff that was necessary when copying from otogrid.
Anybody who wants to give it a try - the Game of Life is on github now! (the 1.1 version).
I've started a separate thread to track progress / issues:
viewtopic.php?t=124578
numan7
the most autistic amongst us
Post by numan7 » Tue Nov 11, 2014 12:35 pm
:party: i have installed my b-rig as of last night!
as mentioned previously, my big plan will be to use it, along the Monome Grid, as a 12 x 8 (or 12 x 16 should i decide to break out all 4 VCAMs) matrix mixer for control signals (the Erica Matrices - will be for timbre). i will call this sketch/patch 'SuperMat' (and i think i'll follow a scanner darkly's example, and start a separate thread to track progress issues
djthopa
Post by djthopa » Tue Nov 11, 2014 12:38 pm
That is a gorgeous system!
Its Great more people are contributing with more sketches!
I have a 4ms vca too, yes!!
a scanner darkly
Post by a scanner darkly » Tue Nov 11, 2014 12:56 pm
Yeah, VCAM is a perfect buddy for the ::b. Actually pretty useful for debugging too, as I find it's easier to tell the voltage judging by the VCAM LEDs as they're not so bright.
Feedback matrix controlled by an automaton is a lot of fun 8_)
scottwilson
Post by scottwilson » Tue Nov 11, 2014 4:00 pm
Technically, since you're writing code, you can set the brightness factor to whatever you like... The factor is in the PCA9655 driver C file if I remember correctly.
That's one such configuration that would be nice to put into a /configs folder... so folks could customize.
s
a scanner darkly
Post by a scanner darkly » Tue Nov 11, 2014 4:06 pm
yeah, i've been meaning to do that. good idea to store it in a config!
Return to “nw2s”
