nw2s::io in the wild
Discussion, support, and resources for our noise making modules and kits.
Moderators: Kent, scottwilson
scottwilson
Post by scottwilson » Fri Apr 17, 2015 9:39 pm
Nice to see one in the wild for the first time... Also cool to know that of all those modules, the 'io is the one that will get used on basically every patch. Note that he's using the rear cabling directly into a patchbay.
Any more photos around that anyone's seen? Some of your own to share?
Post by ignatius » Sat May 02, 2015 12:57 am
ribbon cables out that back to a patch bay :) so simple so sweet. 8 i/o in 10 hp all balanced and level proper.
CF3
Post by CF3 » Mon May 04, 2015 6:59 pm
dubchild
Post by dubchild » Mon May 04, 2015 7:29 pm
ignatius wrote:ribbon cables out that back to a patch bay :) so simple so sweet. 8 i/o in 10 hp all balanced and level proper.
I was just about to pick one of the balanced ones up. Did you get male or female on the rear connector to use with a patchbay?
goiks
Hardest Tryer
Post by goiks » Mon May 04, 2015 10:56 pm
@dubchild - i've got ribbons coming out the back of mine as well, straight into/out of the interface, standard idc connectors iirc, plug in to the headers that the db25 jacks on the front would have. talk to scott about your situation, he's easy to work with and very helpful. quality module. :tu:
www.goike.com
"There is no right answer. Just compromises." - Dave Jones
"Intelligence is generated by communities, by cooperation of some kind." - Brian Eno
Post by ignatius » Mon May 04, 2015 10:57 pm
female but i have a snake connected to it that goes to a 1/4 patch bay. so, the rear connector is same as the one on the front panel
dubchild
Post by dubchild » Mon May 04, 2015 11:25 pm
Thank you both! Looks like a great module!!
scottwilson
Post by scottwilson » Tue May 05, 2015 5:12 am
@CF3 - Mine is the same way. I really don't mind the snakes when you can get the module on the corner like that. What snakes are yours? I like the black hoods.
s
CF3
Post by CF3 » Tue May 05, 2015 6:24 pm
scottwilson wrote:@CF3 - Mine is the same way. I really don't mind the snakes when you can get the module on the corner like that. What snakes are yours? I like the black hoods.
s
Hosa snakes, DB25 to TRS :deadbanana: (don't laugh, they're cheap)
I actually want to run the cables out the back (or even out the side), I just don't want to butcher the Tolex on my Monorocket case. Been thinking about going with two Doepfer A-100-G6's. If I do I can cut the holes nice and neat with a Dremel.
Absolutely love this module BTW. I like it when something does it's job so good you never think twice about it..... it's just there. :tu:
Asym9
Post by Asym9 » Mon May 18, 2015 9:45 am
Here's a photo of my io in the wild. The DB-25s are routed to the back with a cable provided by nw2s. Since there are always a lot of patch cables in the area, I'm glad to have the snakes routed elsewhere.
-7 channels going to the 896.
-2 channels coming from the 896, providing sync and transport control to the iils.
scottwilson
Post by scottwilson » Mon May 18, 2015 9:54 am
Nice - so CV/Clock headed from computer through the 'io?
Using Silent Way for that?
s
Asym9
Post by Asym9 » Mon May 18, 2015 10:10 am
scottwilson, I use an Innerclock Sync Gen iils (the black module to the left) for sync from Logic. Since I prefer to use hardware sequencing for v/oct, my returns back to the modular through the io only send clock and transport info in this photo.
I haven't tested the audio interfaces ability to record cv through the io yet, but I don't suspect I'll have any problems with LFOs and other modulations.
Using the io for sending and returning audio for processing works amazingly well. I couldn't be happier with the io! :guinness:
Thulo
Post by Thulo » Fri May 22, 2015 4:43 am
Installed mine yesterday. It works like a charm.
I run it straight into my SSL X-Desk.
monads
Post by monads » Mon Jun 15, 2015 3:13 pm
CF3 wrote:Been thinking about going with two Doepfer A-100-G6's. If I do I can cut the holes nice and neat with a Dremel.
With an a100-g6 case you don't need to do that if running the cables out the back! Just remove the rear/top panel from the a100-g6. That's what I did 8-)
xonetacular
Post by xonetacular » Mon Aug 31, 2015 9:05 am
goiks wrote:@dubchild - i've got ribbons coming out the back of mine as well, straight into/out of the interface, standard idc connectors iirc, plug in to the headers that the db25 jacks on the front would have. talk to scott about your situation, he's easy to work with and very helpful. quality module. :tu:
Interested in this but I don't want to butcher the case you built me.
Return to “nw2s”
