The new Dynamic Destiny from Macro Machines!
Moderators: Kent, bendedavis
Here you go:waggles wrote:Anybody save the pdf of the manual? Link is dead
LPs released January 2021 - Screen Phoenix - Ethiopian Scared Mechanical & Laserost - Oppussingsokkultister
Soundcloud // Eurorack module demos // MarsMelons - label // Video synth stuff
j_dowe wrote:how does this module do with switching between different audio sources? will I experience pops, or does it smoothly transition?
I think any switch will give you pops because you're switching audio at non zero crossing points. Samplers may have technology to avoid this, but I don't know of a sequential switch that does. I could be wrong.
- Paranormal Patroler
Not sure but I think the 206 has an audio mode for that reason. Either that or the 214 doesn't click with audio, or at least I remember reading as much somewhere around the forum. I never used either with audio so I can't claim that is the case but I'm fairly positive someone pointed out that this feature is not advertised as much as it ought to.
Bad memory, I know.
Bad memory, I know.
- saiteron
- Learning to Wiggle
latest firmware and update procedure?
i got one of these a while ago and while i'm having fun with it i just got to hunting down the manual and it led me here. the one i have doesn't have the sequencing modes (forward, reverse, pendulum, random); when i press both buttons it takes me first to active steps page, then clock divs, then back to the main page.
does anyone have a copy of the updated firmware and/or any advice on how to get the latest firmware and push the update?
If anyone ever wants one of these, send me a pm. I don't use mine a lot.
Re: latest firmware and update procedure?
mine also has this problem (should have tested it more thoroughly).... how can i fix this? firmware?saiteron wrote: ↑Fri Oct 11, 2019 10:56 ami got one of these a while ago and while i'm having fun with it i just got to hunting down the manual and it led me here. the one i have doesn't have the sequencing modes (forward, reverse, pendulum, random); when i press both buttons it takes me first to active steps page, then clock divs, then back to the main page.
