MST Dual AD/ ASR Envelope Issues
Moderators: Kent, synthrotek
Well I found a few pins that were not soldered all the way on the multipin interconnects.
I've fixed these, fired it up and still no good. I also made sure to use some flux wash this time as well. I am now getting a little effect from the switches and such but nothing is triggering.
It is getting kind of tedious for me because my bench is located someplace else, where I don't have anything to trigger it with!
I will need to dig out my old X0Xbox and use that just to throw triggers at it.
I think I may also have to investigate the possibility that I have some dud chips. Have another project that is also exhibiting some bricky behavior, which uses chips from the same batch.
- Maxx mayhem
May I ask where you sourced your chips? (As I am wondering if that is my problem)calaveras wrote:Well I found a few pins that were not soldered all the way on the multipin interconnects.
Well I forgot to take my MST enveloper with me to my bench last time I went so I haven't had a chance to take advantage of the advice Mr.Mattson gave us.
The TL074s I bought are from Tayda. I have heard people report bad things about some chips from them in the past, but I have never had an issue.
I'm going to actually get around to cracking it open again Thursday or Friday.
I've also got a X0Xbox to fix and a few other things, so I expect to hit the bench for a couple days.
- Maxx mayhem
- Maxx mayhem
Finished an MST VCO last night. Also not working.
I really need to bench it out and figure if I have dud TL074's or some other issue. All I know is that for every MST diy that I have bricked I've completed 2 or 3 other projects with no issues.
I'm going through some family health issues right now so I've been using the soldering as a way to relax my mind. But when it comes to troubleshooting I get very frustrated and pissed off very fast.
Let's just say I am your typical male that can not deal with emotions very well.
So I haven't had time to avail myself of Geo's advice.
I have visually inspected the crap out of both, checking the polarity of every single thing. Checking all the joints to be sure they are good.
I really hope it is not bad traces. That would suuuuuuuck.
- Maxx mayhem
I talked to ST yesterday before I even tested my envelope and related to the ongoing problem of my VCO. Now, In the envelope, these capacitors keep getting blown. On the VCO, these diodes keep getting blown. As to the diodes (and I would assume this may be the same thing with the caps as well) ST told me to look for a broken trace on the vco, and using a meter, as the break would likely not be visible under light magnification. Their advice was to start in the area of the affected parts and work outward. Now, I am having problems with 2 /3 of the envelopes I have built, the first one being fine right off the bat. I have run into snags with 4 of 28 kits attempted so far, 1 I replaced, the others I'm intent on defeating.
- Maxx mayhem
I doubt if the cap voltage is the issue. Polarity on the electrolytics I'd believe. If they're backward, they'll blow.Maxx mayhem wrote:OK so now I am thinking the problem is that the caps I'm using (blowing) are 25V. The BOM sends you to Mouser for 50v caps, so that is my next step.
The highest voltage in the EG is 12V. 25V caps can handle double that.
- Maxx mayhem
I verified the polarity, the module worked for a few minutes before failing. Am I looking for a broken trace somewhere?mmm wrote:I doubt if the cap voltage is the issue. Polarity on the electrolytics I'd believe. If they're backward, they'll blow.Maxx mayhem wrote:OK so now I am thinking the problem is that the caps I'm using (blowing) are 25V. The BOM sends you to Mouser for 50v caps, so that is my next step.
[quote="Maxx mayhem"[/quote]
Start posting pix of both sides of both boards. Maybe a second set of eyes can catch something you're overlooking.
I'm assuming you sourced your own parts and didn't get the full kit.
I have no idea what you're looking for. The dozen or so I built all worked.I verified the polarity, the module worked for a few minutes before failing. Am I looking for a broken trace somewhere?
- Maxx mayhem
George, I photographed the logic board, and then put it into photoshop and blew it up. Hit a few joints that looked a bit funky , but then I noticed that if I hold my finger on the bottom 4 pins of U4 (tlo74) it cycles.4-7. One hour later, replaced a resistor in one spot, worked, but now seem to have another issue. I'll hammer this abit more before putting up pix. Thanks
- Maxx mayhem
Alright, I threw around 9 cents worth of parts at it, it was still intermittent. THATs when I figured out I forgot to solder one of the headers.
So now I have 2 rather fine MST Dual envelopes working, one still to get working, but you know... Meatloaf. Anyway No. 3 will have to wait till next weekend.
So technically, Synthrotek was correct. It WAS a broken trace.... sort of, the result was the same...Maxx mayhem wrote:Alright, I threw around 9 cents worth of parts at it, it was still intermittent. THATs when I figured out I forgot to solder one of the headers.So now I have 2 rather fine MST Dual envelopes working, one still to get working, but you know... Meatloaf. Anyway No. 3 will have to wait till next weekend.
- Maxx mayhem
- Maxx mayhem
Long story short-ish, 1 of 6 knobs and 2 of 6 switches were missing from the kit. The module doesn't seem to receive a trigger input to fire the envelopes. It just puts out a constant dc level based on the env depth knob. The invert switches (which were the 2 missing, which we replaced), do have an effect on the dc output level, but just change the scale. Both channels function the same. We also replaced all the tl074 and cd4011 ic chips with no difference. We also verified power supply continuity getting to all of the ic chips.
- Maxx mayhem
- Maxx mayhem
I too have had issues. I've assembled most other MST/Synthrotek modules with no problems until i started working on this guy. I first bought the kit, which was missing some pots and switches from Sythrotek, and they sent out the missing parts.
Never got it to work, so i bought the PCB and put a BOM together of the parts needed for the rear PCB. 2nd try i can get it to work, only if i wiggle the power plug into place. Even then the lights on the front are extremely dim.I noticed that the guide on the site has not been updated to accommodate the latest PCB rev, as some components have been moved, etc.
