Unify expander much quiter than main unit
Confess your sins here. Prayers optional.
Moderators: Kent, BrotherTheo
loydb
Post by loydb » Sat May 02, 2015 8:59 am
If I have the level all the way up on both the base unit and the expander, the expander signal is far, far lower than that of the same source plugged directly into 1-4 on the main unit. This is not desired behavior, right?
Thanks.
15U 168hp Zebrawood case Build Log [FINISHED]: https://www.muffwiggler.com/forum/viewt ... p?t=134540
MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/view ... 797#308797
MFOS Mini-Controller Build Log [FINISHED!]: http://www.electro-music.com/forum/view ... hp?t=42968
scottmoon
Post by scottmoon » Sat May 02, 2015 9:26 am
I was thinking of picking one up. I'll have to follow this thread.
BrotherTheo
Re: Unify expander much quiter than main unit
Post by BrotherTheo » Sat May 02, 2015 5:22 pm
loydb wrote:If I have the level all the way up on both the base unit and the expander, the expander signal is far, far lower than that of the same source plugged directly into 1-4 on the main unit. This is not desired behavior, right?
Thanks.
No, this is not normal behavior. Do you have the pan pots centered?
--BT
Human, all too human...
www.circuitabbey.com
loydb
Post by loydb » Sun May 03, 2015 9:19 am
Yes.
loydb
Post by loydb » Sun May 03, 2015 5:00 pm
I was kind of hoping it was going to be a mis-set jumper or something. But that would have been too easy... :bang:
BrotherTheo
Post by BrotherTheo » Thu May 07, 2015 1:31 pm
loydb wrote:I was kind of hoping it was going to be a mis-set jumper or something. But that would have been too easy... :bang:
So just to verify: the Unify level pot and the Unify expander level pot are set to the same level, and as you move a patch cord from one input to the next the levels are way different? I just did that test on my rig and the levels are the same.
--BT
loydb
Post by loydb » Sat May 09, 2015 9:58 am
Hey, you know what makes the expander work *much* better? Making sure the power cable is completely seated. Since there are no LEDs to indicate power, and *some* signal was leaking, I assumed it was just quiet (well, it *was* just quiet).
Thanks for the response, sorry for the alarm...
:bang:
Return to “Circuit Abbey”
