[Juno-66] Local Off for Juno-66
Moderators: Kent, tubbutec
suitandtieguy
Hammond King
Post by suitandtieguy » Mon Oct 19, 2015 8:10 am
Is Local Off on the to-be-implemented list?
http://suitandtieguy.com
http://stgsoundlabs.com
http://knobcon.com
tubbutec
Post by tubbutec » Mon Oct 19, 2015 9:08 am
It is, yes. The only problem at the moment is, that I have not figured out how to turn it on/off conveniently without destroying any workflow.
Maybe you have some suggestion here.
If I understand correctly the general idea is this:
1) Program a sequencer line using the internal keyboard.
2) Start it, then turn local off
3) Use the internal keyboard to control a 2nd external sequencer..
4) Turn local on again eventually
To me it seems quite complicated to switch into the config menu to turn it on/off each time you want to change something in the sequence...
The only idea I had was that it automatically turns on for sequence selection..
suitandtieguy
Hammond King
Post by suitandtieguy » Mon Oct 19, 2015 4:21 pm
I'm sorry, I was asking about the Juno-66. I should have put that in the subject.
http://knobcon.com
tubbutec
Post by tubbutec » Mon Oct 19, 2015 6:14 pm
Oh.. very sorry I assumed you were talking about the SH-1oh1. Local off for the SH-1oh1 was requested on FB a while ago, so I assumed this was about it.
Anyway to answer your question in regards to the Juno-66: Basically the same answer applies.
I will put it on the feature list for the Juno-66.
What would you use local off for?
suitandtieguy
Hammond King
Post by suitandtieguy » Mon Oct 19, 2015 6:47 pm
it would be useful if i were to use it with an external midi processor in a feedback loop.
thank you. i hope this product is selling well for you.
http://knobcon.com
wjmwpg
Post by wjmwpg » Wed Oct 21, 2015 12:57 pm
About to purchase the 66 myself, and this is definitely a feature I'd love to see. :banana:
marcomoreno
Post by marcomoreno » Thu Mar 09, 2017 2:42 am
Can anyone confirm that Midi local off feature is still not implemented in the current Juno66 firmware?
nutjob
Re: Local Off for Juno-66
Post by nutjob » Sun Oct 18, 2020 5:34 pm
Local off would be great. There could be "local keyboard control" item added to the MIDI section of the config menu. The Kenton MIDI kit that was previously installed in my Juno had this feature. Pairing the Juno with an MPC sequencer works much better this way.
tubbutec
Post by tubbutec » Wed Jan 13, 2021 7:37 am
Local off is now implemented in firmware 1.29
polysixer
Post by polysixer » Wed Jan 13, 2021 4:16 pm
Omg thanks so much Toby!
nutjob
Post by nutjob » Thu Jan 14, 2021 7:24 pm
This is excellent news! Thanks Toby!!!
:spin:
Edit: Tested - works perfectly. It's now as if my juno60 and mpc60 were made for each other.
Were the detuning values changed? I seem to have better control over detuning now - perhaps this was the exponential spread amount control update with v1.28 - I like it!!!
Return to “Tubbutec”
