µTune question
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
Steevio
Post by Steevio » Wed Feb 14, 2018 4:09 pm
UPDATE!!
looks like a faulty SD Card or socket, but I havent got another one to try.
with a bit of wiggling it reads, but its not consistent.
will report back tomorrow with a new SD Card.
Steevio
Post by Steevio » Thu Feb 15, 2018 4:48 pm
OK so the bad news is that I bought a new SD Card, (8Gb it was the smallest I could get.)
I copied the contents of the Tubbutec SD Card onto it, put it in the uTune and it didnt work, it flashed on the screen for a millisceond (LOAD etc.) then back to No SD Card.
The original has to be wiggled a bit to get it work, and once it connects it seems to stay on OK, but when you first put it in it just says NO SD Card, and it is difficult to get to work.
I can only assume that the SD card socket is faulty.
Could I be doing something wrong with the new card ? Is it just a case of copying the contents over ?
I named it Tubbutec the same as the original.
Phil999
Post by Phil999 » Thu Feb 15, 2018 6:50 pm
maybe it's just some dust inside the socket.
tubbutec
Post by tubbutec » Sat Feb 17, 2018 2:10 am
Hi Steevio,
yes looks like the socket has a faulty contact. Namely the one which detects if a card is plugged in or not.
Probably has nothing to do with your update, but is a hardware problem.
Please contact us at mail@tubbutec.de an we will figure something out.
10 Miles High
Post by 10 Miles High » Wed Oct 17, 2018 11:49 am
Hey guys,
has anyone the beta firmware installed? How smooth does it run?
The features are very promising, wanted to ask if someone has tried it out.
10 Mh
tonymasiello
Post by tonymasiello » Wed Oct 17, 2018 8:23 pm
I tried it, but quickly backed it out. Besides being quite different in appearance, my module did not function properly, and the note data on the display showed values much higher than 128. I went back to the last stable firmware, and did a reset. FWIW, I have the older hardware version. Not sure if that was a factor.
10 Miles High wrote:has anyone the beta firmware installed? How smooth does it run?
Return to “Tubbutec”
