µTune MIDI Question #2
Moderators: Kent, tubbutec
hageir
Post by hageir » Sun May 13, 2018 8:31 am
Hi there, excellent work!
Does the µTune 'microtune' MIDI notes?
If so; polyphonically?
i.e. could I insert this between a controller and a synth (MIDI) and get microtuning on that synth (in guitar/mono mode*)?
*pitchbend values on a seperate MIDI channel I guess..
chess1
Post by chess1 » Sun May 13, 2018 9:56 am
I was wondering the same thing. My understanding is that most hardware (digital ?) synths are set to equal temperament. I am looking forward to exploring this myself.
At the risk of a slight hijacking. Can anyone tell me how the VCO tuning process works ? Not in the technical sense, but literally how you use this feature.
hageir
Post by hageir » Sun May 13, 2018 1:23 pm
chess1 wrote:I was wondering the same thing. My understanding is that most hardware (digital ?) synths are set to equal temperament. I am looking forward to exploring this myself.
Cool man, no worries,
it is by far best implemented on my REV2 (global setup -> scales)
My VFX supports it, albeit I needed to tune each note on the keyboard, one by one LOL
But the ESQ-1 is more favored (the VFX is cool, the ESQ-1 is a bit simpler and not so much complex menu diving).
I had a X5DR, it's a bit boring but it had an uploadable scale (SysEx I guess), the next on the list are the Yamaha DX and SY/TG synths.
The excellent Korg PS3200 (amongst others) VST recreations by fullbucket have tuning knobs for each note:
https://www.fullbucket.de/music/fb3200.html
But those all implement microtuning in one way or another, what I'd like is a MIDI 'filter/effect' that would basically pitchbend the MIDI notes, but channel separated (some synths have guitar/mono mode with independent pitchbend, wheel and CCs, etc.)
It was super easy to set up on my Matrix 6R, but that's long gone :(
One cool implementation of a MIDI filter/effect is that simple-design 'loop'-cable from Retrokits, it just connects to MIDI OUT and loops back into MIDI IN
with a processor in the cable:
https://www.retrokits.com/shop/rk002/
That would be cool if it supported microtuning.
tubbutec
Re: µTune MIDI Question #2
Post by tubbutec » Thu May 17, 2018 5:55 am
hageir wrote:Hi there, excellent work!
Currently no, but the next firmware will support both, pitch bend and Real Time Sysex Tuning modes
tubbutec
Post by tubbutec » Thu May 17, 2018 5:59 am
chess1 wrote:Can anyone tell me how the VCO tuning process works ? Not in the technical sense, but literally how you use this feature.
I can only point to the user manual. Maybe you can tell us which part is unclear:
To perform a calibration make sure your VCO is plugged into CV-out. (Let's say on channel 2). Select channel 2 and enter 'Manual VCO calibration'.
Now plug the output from your VCO into GATE-in on channel 2. In the upper left corner you will see the detected VCO frequency. Navigate to the 0V entry and press enter. µTune will now output 0V and save its frequency. When the frequency reading is stable, press enter again and navigate to the 1V entry. Press enter and µTune will now output 1V. The pitch of the VCO should now be an octave higher. µTune shows you the difference between the detected and the expected pitch. If the detected pitch is negative you have to increase the voltage, if it is positive you have to decrease it. Try adjusting the voltage until the frequency difference reads 0Hz. depending on how stable your VCO is this might not quite be possible due to pitch drift, but try to zero in as good as possible.
When finished repeat this for all voltages.
You can now save the calibration. It is completely independent from the channel, so if you later connect the same VCO to channel 1, you can just load the file into it.
hageir
Post by hageir » Tue May 22, 2018 9:04 am
HOLY SMOKES :hyper:
b_d
Post by b_d » Thu Jan 24, 2019 1:01 am
MIDI->microtonal MIDI conversion is in the beta 1.11 (https://tubbutec.de/%C2%B5tune-updates/), this is actually the main reason I bought uTune.
If by Polyphonic you mean chords, then yes.
klangdicht
Post by klangdicht » Mon May 20, 2019 8:45 am
b_d wrote:MIDI->microtonal MIDI conversion is in the beta 1.11 (https://tubbutec.de/%C2%B5tune-updates/), this is actually the main reason I bought uTune.
So me too. I just bought my µTune today at Schneiders Laden! (btw, this is my first post in the Tubbutec sub-forum...)
I am still wondering how to do microtuning from MIDI in to MIDI out. Firmware 1.11 beta is installed.
tubbutec
Post by tubbutec » Mon May 20, 2019 9:59 am
In the midi note routing screen. You now have a optional little µ next to the arrow when routing. This enables midi pitch translation
Currently settings from midi out are used. Set the method to sysex or pitch bend here.
klangdicht
Post by klangdicht » Tue May 21, 2019 11:04 am
tubbutec wrote:In the midi note routing screen. You now have a optional little µ next to the arrow when routing. This enables midi pitch translation
Thank you! :-)
I tried it yesterday with four polyphonic synthesizers and MIDI in/out, but it didn't work yet. I loaded a mean tone scale, tried scaling with pitchbend and SysEx, but the synthesizers play bizarre scales. Chords do not work well (for example, a C major chord becomes something that sounds like diminished C). I will test more settings.
tubbutec
Post by tubbutec » Mon May 27, 2019 4:28 am
Thank you! :-)
The pitch bend range is unfortunately not defined in the midi standard. That is why you can adjust it in the µTune. Polyphonic translation only works in sysex mode, not in pitch bend mode (pitch bend is not a note specific, but channel specific message)
chess1
Post by chess1 » Sat Nov 09, 2019 2:17 am
Are there any videos out there in the wild that show this amazing feature in action ?
Bubbles
Re:
Post by Bubbles » Sat May 23, 2020 7:59 pm
Please post videos for ALL uTune functions!!
Return to “Tubbutec”
