µTune - midi to clock
Moderators: Kent, tubbutec
wxyz
Post by wxyz » Wed Mar 13, 2019 2:02 pm
Trying to set up a standard midi cable from a computer to create Eurorack clock out. How should the configuration look like?
tubbutec
Post by tubbutec » Mon Mar 18, 2019 4:44 pm
Hi,
first make sure your DAW does send a midi clock, sometimes this has to be enabled.
Then in the µTune clock routing, route the clock from your midi source (usb or din) to µT
In the µTune channel config configure the gate-out to 'midi clock' and set the divider to your liking.
eircom
Re: µTune - midi to clock
Post by eircom » Wed Jul 08, 2020 7:35 pm
Hi. Is that possible to generate midi clock from CV impulses? I wonder if i'd be able to clock my Norns Shield with it — from the modular? Thanks!
tubbutec
Post by tubbutec » Sun Jul 12, 2020 2:30 am
Convertig an analogue clock to a midi clock is tricky and requires a specialized tool.
I can recommend the Audiowerkstatt trigger2midi2trigger:
https://tubbutec.de/product/audiowerkst ... i2trigger/
Glacial Creep
Post by Glacial Creep » Wed Mar 24, 2021 4:44 pm
Thanks for the explanation - I was also going to ask if you plan to include analogue to MIDI clock as a feature on the µTune, but gather it's not on the cards!
Cheers :)
Return to “Tubbutec”
