Roland CR5000 - Bass drum (UniPulse)
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
uthb
Post by uthb » Thu Nov 05, 2020 10:57 am
Hi
Has anyone done the Unipulse mod on either CR5000 or CR8000?
I just installed mine on CR500 including the additions from the user on this board (i.e. Clave 5+v and Low tom polarity), and I got everything working as it should. Well almost, it seems like the bass drum is lacking just a tiny bit in the low end, so it's a bit more tight and snappy than when I use the internal sequencer on the CR500. I've tried different velocity levels, polarity etc. in the configuration and it's quite hard to replicate.
Does anyone have any good input on how I could proceed from here or what the potential 'issues' could be?
All the best
Jesper
Nightly Closures
Re: Roland CR5000 - Bass drum
Post by Nightly Closures » Thu Nov 05, 2020 10:59 am
Totally jealous about that machine with that mod; congrats. Have you contacted tubbutec? They’ve been really responsive when I’ve had questions in the past.
uthb
Post by uthb » Thu Nov 05, 2020 11:14 am
Agreed, it certainly opens up possibilities! :-)
I didn't contact Tubbutec directly as the website states it's better to ask in this forum due to 1) faster responses and 2) knowledge sharing - so hopefully Tubbutec or someone else can chip in
tubbutec
Re: Roland CR5000 - Bass drum (UniPulse)
Post by tubbutec » Thu Nov 05, 2020 2:27 pm
Hi, coincidentally we are currently installing uniPulse in two CR-8000. Will listen closely to the bassdrum and see if we can duplicate your issue..
uthb
Post by uthb » Thu Nov 05, 2020 4:39 pm
Cool - will record some audio tomorrow for comparison (internal sequencer/unipulse triggering) :)
uthb
Post by uthb » Sat Nov 07, 2020 8:02 am
Just had a closer look at the configuration and compared to the sounds as triggered by the internal board.
I've changed to 'open hihat' to rectangular shape with a max length around 0.3-0.4 as the decay was too long compared to the internal sounds - just if others wanted to do the same.
The BD is still not quite identical, but it's not a major issue to be honest.
ndkent
Post by ndkent » Sat Nov 07, 2020 10:16 am
Haven't started but it's on my agenda. Shouldn't one be able to scope what the internal sequencer puts out for the BD via a probe?
uthb
Post by uthb » Wed Nov 11, 2020 3:29 pm
Yeah, that's probably the best next step - will not get time to do it in the coming weeks though, but will do it when I install the separate outputs and report back :-)
durwin
Post by durwin » Mon Feb 01, 2021 9:07 pm
Any more progress on this? I'm at the same point for my CR8000 - my bass drum is a little more clicky and less warm thud. Have tried shorter decay times than 1.27 and alternate shapes to no avail.
tubbutec
Post by tubbutec » Thu Feb 18, 2021 5:45 am
Hi,
finally did some tests, this is the correct setting for the basedrum:
NEGATIVE POLARITY, 5V, DECAY shape
Return to “Tubbutec”
