utune midi velocity
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
gmeecc0_
utune midi velocity
Post by gmeecc0_ » Sun Dec 13, 2020 4:37 pm
hello,
i’m having a hard time figuring out how to control/adjust MIDI out velocity. is this possible through using midi cc? any help would be much appreciated. thanks!!
tubbutec
Re: utune midi velocity
Post by tubbutec » Mon Dec 14, 2020 3:29 am
Hi, very simple. Just choose an unused CV-out and configure it as "Velocity" and choose the velocity source from another channel.
Example:
Channel 1,2:
Midi in channel 1
CV-out: pitch
Gate-out: Midi gate
Channel 3,4
Midi-in channel: OFF
CV-out: Velocity
Velocity from: channel 1 (for channel 3) and ch 2 for channel 4
If you install firmware 2.06, you can also see the velocity output as a bargraph in the main menu.
gmeecc0_
Post by gmeecc0_ » Mon Dec 14, 2020 11:08 am
thanks for the reply,
wouldn’t this be reporting the velocity of an incoming midi signal?
i’m wondering how to affect the velocity of the midi signal going out of the utune. i can only get a 0 or 100 velocity to register when sending midi OUT.
also i only have two channels.
thanks again.
tubbutec
Post by tubbutec » Mon Dec 14, 2020 11:11 am
Very sorry, I misunderstood your post.
Currently the outgoing velocity can not be adjusted. We already have this on the TODO list and it will be implemented eventually:
viewtopic.php?f=78&t=241270
Return to “Tubbutec”
