I'm having issues figuring out what should be working in terms of transposition and have a few questions.
1) In terms of cv transposition I can't tell from previous posts and the manual what currently works and how it is supposed to work.
2) I'm not able to get the midi transposition to work, i've tried 2 different scenarios
1) midi in from keystep out into a neutron and am able to get the scales to change pitches to the correct pitches but transposition doesn't do anything, note: tried using all different din tuning settings and sysex
2) midi in from keystep out into a computer with usb, using login with softube synth 72 and am able to get the scales to change pitches to the correct pitches but transposition doesn't do anything, note: tried using all different usb tuning settings and sysex
thanks
[µTune] Midi Transposition
Re: Midi Transposition
1) Using a CV-input, you can transpose another channel
2) Midi transpose? Which parameter are you referring to, here?
https://tubbutec.de
mail(ät)tubbutec(döt)de
Re: [µTune] Midi Transposition
Page 16 of the manual for Output Config (I think i'm confused as to what this setting is for) :
"Transpose: An offset added to the midi note when sending.
This transposes midi coming from the CV to Midi converter
https://tubbutec.de
thank you
