ATN8 manual?
Support and discussion for Antumbra modules and DIY builds
Moderators: Kent, antumbra
ForAiur
ATN8 manual?
Post by ForAiur » Wed Sep 16, 2020 1:41 am
I know the module is pretty simple but I would love to read about all the possibilities, so maybe I‘m missing something. I‘m only using at as an attenuverter, but want to try it as a mixer and don‘t know about phase cancellation and so on.
snowtires
Re: ATN8 manual?
Post by snowtires » Tue Oct 13, 2020 5:06 pm
You can use it as a mixer as long as you only plug something into the out jack of the last track you want in the mix, and only that track. As far as the modules possibilities, other than a mixer and attenuverter, with nothing plugged into the input, the output of any of the unmixed tracks can be used as an offset. You can select between 5v and 10v (the . and .. selections at the top of the modules), with channels 1-4 and 5-8 being grouped together. One thing with this is that you have either use the top channels for offset or patch a dummy plug into the out of the channel above or anything above that that will get mixed in with the offset.
Return to “Antumbra”
