Any: The search for the ultimate kick machine
Post your patches here! Put the format(s) in the subject.
Moderators: lisa, Kent, Joe.
The Grump
Post by The Grump » Wed Sep 25, 2019 7:13 pm
For many years I have been on a quest to find the device or devices that will consistently yield the best of the best for whomping kicks that techno relies upon. I have used TR-909's on and off, as well as TR-808's, I have a Jomox XBase09, Volca Kick, several hardware synths, and more software plugins than most dieties you would care to name.
In software, the best tool I've found has been Sonic Academy's KICK2 plugin, but software isn't stable enough for live use, at least not when it comes to using that particular plugin. The D16 Drimazon is actually pretty solid, and sounds quite good, but it's really just a modded 909 emulator.
Years ago, I discovered the joys of using my Microwave Rev A to build kicks with the Palm VCF, but had kind of set it by the wayside. However, using KICK2 gave me an idea. The thing that makes KICK2 such a weapon is the ability to create very complex, FAST multistage envelopes, especially for the frequency of its sine generator. How about creating a similar system in the analog domain by applying the Wave Envelope in the Microwave to the cutoff of the VCF?
Let me tell you: holy mother of ZOMFGWTFBBQ???!??!
The Microwave patch is basically Osc 1 set to a triangle, which is third to last wave on any wavetable, volume 5 just to give the VCF something to start its self oscillation. Osc2 is volume 0, not in use.
Filter resonance is at about 65%. Anything above 50% will do.
I set the filter mod1 amount to +63, Mod1 Control to Modwheel, and Mod1 Source to the Wave Envelope.
Then I just go into the Wave Envelope, and add or subtract points as I need, and between the filter ADSR, env amt, keytracking, cutoff, combined with the modwheel and Wave envelope values, I have the potential makings of some of the biggest, baddest, thickest, stinkiest analog kicks around if compressed and EQ'd properly.
What have you found to be your ultimate kick machine so far?
Post by dubonaire » Wed Sep 25, 2019 10:21 pm
Not sure if I have an ultimate, depends on what I'm doing. Jomox 999, Tiptop BD808 is really good. For KICK2 I load samples of kicks I've made into the SP-16.
Post by ignatius » Wed Sep 25, 2019 11:07 pm
have made some kicks i like w/nord lead 3 and the fm algorithms.
ultrakick max for live device is quite extensive and full of parameters to make specific changes.. tiny changes.
https://isotonikstudios.com/product/ult ... rum-synth/
there's many ways to make kicks in modular systems. i like FM for getting those lows with that tough of high buzz in there. filters and oscillators and a good expo attack.
cptnal
Post by cptnal » Thu Sep 26, 2019 3:29 am
Whenever I think kick this comes to mind:
Post by dubonaire » Thu Sep 26, 2019 3:32 am
ignatius wrote:i like FM for getting those lows with that tough of high buzz in there. filters and oscillators and a good expo attack.
Yep same. I have got some nice kicks out of FM'd Rubicon and also Synthtech E370.
The Grump
Post by The Grump » Sat Sep 28, 2019 6:49 am
There sre some really good suggestions, thanks for chiming in. I sometimes load kicks I've made in KICK2 into my MPC1k, for some reason, that unit and I have never quite clicked. Maybe one day.
minigmgoit
Post by minigmgoit » Fri Oct 18, 2019 8:43 pm
I recently got the Jomox Kick Module and for me it's got everything I could want. It's got huge meaty kicks and I find myself using it when I'm chopping up breaks in my modular to augment the sampled kicks and just have it triggered by the same signal as other kick. I really love that module. I was a bit bummed out about having to spend so much on a simple kick drum however once I started using it and hearing how it came through in the mix it was love. And it just sounds so utterly epic through a large sound system.
I like the tiptop 808 too, nice and deep and good for more mellow "daytime" techno/house. I've got a satisfactory kick from the Sara Filter too.
b9
Post by b9 » Mon Oct 28, 2019 6:33 pm
my profile pic recorded into an akai s950 gave me the best digital kick sample I've ever used. Still exploring purely modular possibilities.
indigogogo
Re: Any: The search for the ultimate kick machine
Post by indigogogo » Tue Jan 14, 2020 1:00 am
WMDs Crater does a really nice job, morphing from standard house kicks, to grabber square crunchinesss, to smooth sub bass lines.
3hands
Post by 3hands » Wed Jan 15, 2020 8:05 pm
I’ve owned 909’s, 808’s all that...
The one Im using a lot now is the SYO.5
It’s a recreation of a Pearl Syncussion channel. And holy Christ. Whenever I use it it automatically goes to a limiter, and my monitor volume has to get turned down. It makes frequencies that make my testicles feel funny (yes that’s tmi but it’s hilarious).
I love it. And triggered from the Roland TR09, it’s just a fantastic thing!
Gum is fun, but not on a cat.
My minds an art gallery.
astromass
Post by astromass » Mon Jan 20, 2020 10:15 pm
+1 on the WMD crater.... versatile and sounds amazing! Love WMD’s stuff. :party:
what gives?
Post by what gives? » Tue Jan 21, 2020 12:53 am
BIA
Return to “Synthesis Techniques”
