Rene 2/ANY: Pendulum Sequencing Tips with Direction Input
luketeaford
Post by luketeaford » Thu Nov 07, 2019 8:12 pm
If your sequencer has a direction input, you can achieve pendulum programming pretty easily with a simple formula for clock division.
Suppose the number of steps in your sequence is N. A perfectly even pendulum is achieved with a clock division corresponding to 2N - 2. So a 4 step pendulum would require a clock division of 6.
If you want the sequence to advance one step with each pendulum iteration, which is a cool effect in its own right, use the formula 2N - 1. So an 8 step pendulum that advances one every iteration requires a clock division of 15.
Some bonus tips for Rene 2: you can also use the location CV to offset your sequence manually or with control voltage, and if you have a Tempi, you can generate very complicated sequences where you shuffle the clocks, lock into exact repeats, explore the entire set of possibilities, move around in snake modes or thru the Z-axis... it's a lot to explore. :tu:
luketeaford
Post by luketeaford » Thu Nov 07, 2019 8:14 pm
Here is a quick demo of the technique:
atomboyd
Re: Rene 2/ANY: Pendulum Sequencing Tips with Direction Input
Post by atomboyd » Mon Jun 22, 2020 5:37 pm
This is really great, thanks for sharing!
cptnal
Post by cptnal » Wed Jun 24, 2020 5:41 am
2N - 1 sounds cool. :tu:
Is it finished?
Latest Tune:
Racks: Big Case, Top Row, Funboat, Tinicase
