Making LFOs more complex
Post your patches here! Put the format(s) in the subject.
dooj88
Post by dooj88 » Thu Aug 20, 2020 9:57 am
what are your favorite ways of modulating/processing your simple LFOs to get more complex results? obviously you could just say 'use the CV jacks and modulate them,' but i'm interested in things you've gone back to doing. i've got wavetable lfos as well, but i want to push the simpler ones harder.
thought it might be fun to share some ideas and maybe learn a thing or two. so i'll throw out the obvious ones and add a few favorites:
-mixing two together in a mixer
-sequence into v/oct or fm inputs
-running through a modulated filter and fed back to itself
-free running lfo through an CVable offset controlled by another synced to a clock
EASYBOY
Re: Making LFOs more complex
Post by EASYBOY » Sun Aug 23, 2020 1:08 am
Great ideas.
Finally the pitch range of my turing machine is controlling all my LFOs
wiggies
Post by wiggies » Tue Aug 25, 2020 10:18 pm
LFO into wavefolder. Then modulate the wavefolder. Maybe with the LFO.
hawklord2112
Generally and Specifically
Post by hawklord2112 » Wed Aug 26, 2020 4:51 am
running it and a faster attenuated/polarised lfo into my doepfer Max/Min (a massively underused module in my rack) gives a bit of a wobble at the top / bottom of the cycle maybe?
stk wrote:Hawklord IS the Annoying Checkout Guy!!!!1111
nrdvrgr wrote:Hawklord IS the Annoying Synth Neighbor!
hawklord2112
Post by hawklord2112 » Wed Aug 26, 2020 5:02 am
and / or running it through a bit crusher / modifier can be funtime
Post by lisa » Wed Aug 26, 2020 5:06 am
Run it through a filter and crank up the resonance to get a hairy version of the LFO.
My second ever track using Mutable Instruments Rings. Here paired with Make Noise 0-coast and Arturia DrumBrute and Korg Minilogue. A rather bittersweet piece. ❤️
hawklord2112
Post by hawklord2112 » Wed Aug 26, 2020 5:47 am
oh my
SJ900
Post by SJ900 » Wed Aug 26, 2020 2:46 pm
I would never have thought of that, but it did make me wonder what would happen if a LFO was passed through a wavefolder - the result is ... complex
electricanada
Post by electricanada » Wed Aug 26, 2020 2:56 pm
Lfo into A-189-1 into quantizer makes a nice sequencer.
Keltie
Post by Keltie » Wed Aug 26, 2020 3:00 pm
+1 on min max. MI kinks works well for this.
Mixing via a mutes module so you can knock in / out various parts of the sum works nice for me too.
yhf
Post by yhf » Wed Aug 26, 2020 4:02 pm
I like to send two or three (often slow) unsynced square wave LFOs into a digital logic module and take the various outputs ("And", "Or" etc.) to trigger sounds, start envelopes, advance or reset sequences and so on. What you get, basically, is ever-changing time windows in which those triggers, modulations etc. can happen. I use the Doepfer A-145-4 and A-166 for this but any LFO(s) and (digital) logic modules should be fine.
dragulasbruder
Post by dragulasbruder » Sun Aug 30, 2020 12:04 pm
Sample-Hold feedback is fun--LFO clocks SH, SH sampling noise (or anything), SH feeds LFO CV input, take any shape for per-cycle randomized speed. This is *really* fun when you use this LFO as the clock source, especially if you have control over the amplitude of signal at the SH's sample input.
Another great sample-hold one is a "baby rungler" patch. LFO1 clocks the SH, LFO2 feeds the sample input. SH output goes back to CV inputs of the two LFOs. An attenuverter for the feedback path from SH to LFO2 is super helpful, because negative feedback acts pretty different. Even just a tiny bit of feedback gets this patch pretty spicy. Tap any signal from anywhere, they're all doing something cool. And yes, this sounds dope at audio rate.
Multiplying two LFOs with a DC-coupled ring modulator/BPVCA is really cool, sync can also helpful here. This also works great with a clock-synced digital LFO and a free-running analog one.
Now offering sliding-scale SYNTHESIS and AUDIO PRODUCTION LESSONS during the pandemic--please PM for details!
WTB Wish List: https://www.modulargrid.net/e/racks/view/1224624
MY MUSIC: https://www.soundcloud.com/wish-fulfillment
dragulasbruder
Post by dragulasbruder » Sun Aug 30, 2020 12:09 pm
I watched this Rob Hordijk video and then started trying to pass *everything* through wavefolders. Sequences! Envelopes! basically anything but a raw square wave, gate or trigger does something inspirational.
natureclubcassettes
Post by natureclubcassettes » Sun Aug 30, 2020 12:18 pm
My 143-9 is pretty much always patched as such:
1. Random output from 118 into CV 1 jack (the 118 random out has a built in output attenuator, perfect for this; the bipolar signal signal works great with the bipolar LFO it is affecting)
2. Inverted sine or inverted cosine patched back into CV 2 jack, attenuverted in either direction.
Lots of really wild modulation to be found in this simple quadrature sine LFO....
Rex Coil 7
Post by Rex Coil 7 » Sun Aug 30, 2020 2:51 pm
...-mixing two together in a mixer ...
Nope ... get funky ... mix four LFO signals together in a quad VCA/voltage controlled mixer. Then move around all four VCA outputs using a Planar2 joystick (vector control). Or go with two LFO signals into a VC mixer/VCAs and control with a vector controller ... use the unused two vector channels to control the two LFO frequencies/speeds. So the vector joystick is controlling the LFO mix and the LFO speeds both independently. I think the Planar2 actually has four VCAs in it, and can send vector control and XY control simultaneously. Pick a couple of LFO sources and plug up!
:tu:
... I'm dyin' in a vat in the garage ...
electricanada
Post by electricanada » Mon Aug 31, 2020 5:19 pm
Nice thread. I have collected a number of patch ideas for my patch idea notebook.
CrysWiz
Post by CrysWiz » Mon Sep 28, 2020 10:25 pm
Freq mod one LFO to the next to the next. Do logic manipulations. Run them through stuff like NonLinear Circuits Neuron and similar.
turning the world on its ear since 1981
thelowerrhythm
Post by thelowerrhythm » Mon Sep 28, 2020 10:32 pm
Hands down, Vector Space.
"Ah yeah, you’ve got that strange blend of apathy and self-flagellation that somehow gets you where you want to go."
thetwlo
Post by thetwlo » Mon Sep 28, 2020 10:41 pm
or Wiard Jag, or NLC Let's Splosh.
Also, XAOC Samara, Plan B Model 14, Circuit Abbey Gravity Well, Horstronic Waveslicer....
pekbro
Post by pekbro » Mon Sep 28, 2020 11:00 pm
I just use an envelope, and then modulate it with an LFO.
dragulasbruder
Post by dragulasbruder » Tue Oct 06, 2020 8:55 pm
analog logic is your friend here too. max/min functions are really great for when you want a complex shape.
sir stony
Post by sir stony » Wed Oct 07, 2020 2:18 am
LFO into comparator, adjust the threshold to target a specific part of the wave, and with that, trigger something else to shape the lfo waveform, could be a short fuzziness by a wavefolder, or a stuttering by a gate/vca, or a ducking/expanding dynamic effect, or... well, this is modular, just think up something ;)
a very late PS.: I find that unless you are in real need for a very particular kind of modulation like this, for example when going for the sound design for an engine kind of thing, in the musical aspect it's usually not worth the effort and number of modules needed. I was just now taking a look at what else I could do, and while there are countless ways, looking beyond the initial question of reshaping an lfo, the result is typically one that we could have had far easier by using a wavetable lfo or simply a (looping) envelope. Basically, that was my initial idea of going modular at all: get an lfo and modulate it to hell and back, using it as clock source, splitting and delaying it, slew the parts, mix them back into one, offset or inverted, add noise, add random values with s&h... and if you stop that lfo, it all dies. That was my first rack concept. :)
Return to “Synthesis Techniques”
