ANALOG VU-meeters:
"ЛИУ" series based on vintage tube "6e2"
"СИУ" series based on rare vintage Soviet indicator "M68"
"NEON" based on modern Chinese indicator with a bright backlight
• Switchable backligt with variety of colors allow you to choose the device for any system.
• High-qualit drivers do not interfere with the signal
• Built-in passive mult for three inputs/outputs + one attenuated input/output
• Low current consumption of "СИУ" modules allows the use of multiple modules in your modular
* "ЛИУ" units may slightly lower the source volume
DIGITAL VU-meeters:
"ДИУ" series - led indication devices for incoming signal.
• A wide variety of colors and models will allow you to choose the device for any system.
• With the jumper you can choose one of two modes: full scale or floating point.
• You can order an exclusive coloring!
"ДИУ-32к"
• 32-segment VU-meter with sensitivity adjustment and thru output.
• 6 visual modes, additional settings, adjustable brightness.
ModularGrid: https://www.modulargrid.net/e/racks/view/839349
Insta: http://www.instagram.com/paratekorg/
"ЛИУ" - "СИУ" - "ДИУ" VU-meeters series
PARATEK - aesthetics of the Soviet cyberpunk!
Grid: http://www.modulargrid.net/e/vendors/view/749
insta: http://www.instagram.com/paratekorg/
- GiantSuperCell
- Learning to Wiggle
- Contact:
Re: "ЛИУ" - "СИУ" - "ДИУ" VU-meeters series
I wanted to thank you for the great handling! After a long journey (RUS-> AUT) the module reached me well packaged. No problems with customs. Everything as requested and described. Great service and quick response to my emails. It was definitely not my last order. THANK YOU.
