Power cable question
- pugix
I'm planning on putting two DIY boards behind one panel. I use the 4-pin MOTM power connector to connect the supply. I was wondering if the Power Cable 6P-6P can be used to run power from one Mattson board to the other.
Richard
https://www.pugix.com
Re: Power cable question
Absolutely.pugix wrote:I'm planning on putting two DIY boards behind one panel. I use the 4-pin MOTM power connector to connect the supply. I was wondering if the Power Cable 6P-6P can be used to run power from one Mattson board to the other.
- pugix
I ordered a couple of 6P-6P cables! Thanks.
Now I see the advantage to having both types of power connector on each board.
Richard
