How do I get this effect on vocals
Discussing gear, production, and ideas for making noise music. Enough JMJ, let's rock like Merzbow!
noise_not_music
Post by noise_not_music » Mon Jan 16, 2017 9:19 am
Ive heard alot of people use this effect in more industrial styled noise stuff, like genocide organ, puce mary etc. And I was wondering on how to get something similar. I know its gotta be a mic ran through certain effects pedals cause its able to be done live too not just studio after effects. Any ideas appreciated
Example:
https://www.youtube.com/shared?ci=67mmChN4PS8
sexcomputer
Post by sexcomputer » Mon Jan 16, 2017 5:28 pm
pretty sure you could do this with a distortion, delay, and modulation of some kind, like a deep chorus. I've got an old delta labs effectron that could probably replicate that vocal sound.
MrTurboparrot
Post by MrTurboparrot » Mon Jan 16, 2017 5:42 pm
probably any overdrive, fuzz or distortion you can name. You could try tons of effect pedals, but you'd probably be surprised that NOT turning everything to 12 would work, i.e. a nice crunch setting from a good ol' boss OD-2 or something like that.
Unlike the post above, I do not hear a lot of modulation, just a cr@p ton of white and/or pink noise and overdrive.
"You have to go on and be crazy. Craziness is like heaven." Jimi Hendrix
pstanig
Re: How do I get this effect on vocals
Post by pstanig » Tue Jan 17, 2017 1:51 pm
noise_not_music wrote:Ive heard alot of people use this effect in more industrial styled noise stuff, like genocide organ, puce mary etc. And I was wondering on how to get something similar. I know its gotta be a mic ran through certain effects pedals cause its able to be done live too not just studio after effects. Any ideas appreciated
Example:
That's most likely a band pass filter (or ms20 dual filter) with resonance cranked relatively high and lfo modulating cutoff at sub-audio (but fast-ish) rate. Some overdrive and delay before the filter. Maybe no overdrive, just overloading the ms20 filter.
beatcleaver
Post by beatcleaver » Tue Jan 17, 2017 1:55 pm
I'm not familiar with the people you mention but FWIW I've heard that the classic Ministry style vocal didn't use distortion - they used several compressors in series, mashing the hell out of the signal.
palimpsest
Post by palimpsest » Fri Jan 20, 2017 5:26 am
It's a modulation effect (flanger/phaser/chorus) with a fast LFO rate
mt3
Post by mt3 » Tue Jan 24, 2017 11:02 pm
Metasonix Auto-Tune.
noise_not_music
Post by noise_not_music » Wed Jan 25, 2017 12:31 am
mt3 wrote:Metasonix Auto-Tune.
Isn't that a computer editing effect?
metasonix
Tube Pioneer
Post by metasonix » Wed Jan 25, 2017 9:16 pm
:haha: :animal: :goatse:
Hans-g
Post by Hans-g » Thu Feb 02, 2017 12:31 pm
I am tired of getting the spam of Hans Zimmer everytime I click on a video.
Unborn Gore
Post by Unborn Gore » Fri Mar 10, 2017 4:48 pm
The tremolo on the Digitech Vocal 400 would get you there.
Sandrine
Post by Sandrine » Fri Mar 10, 2017 9:38 pm
A Reflex LiveLoop could make this sound.
Modulating the sample rate with a 10 Hz LFO during the delay and feeding the feedback out to the other channel input would have a slapback effect that would also be modulated with varied phase pretty much just like this.
It sounds like there's some bit reduction going on in the backing music and perhaps some pre phase low bit distortion on the vocals. The feedback is also being varied :tu:
JM Midnight
Post by JM Midnight » Sun Mar 10, 2019 2:34 pm
I know that Genocide Organ uses multiple MS20s in their setup. The vocals sound like delay and ring modulation filtered through the MS20. Could be totally wrong.
artilect99
Post by artilect99 » Tue May 28, 2019 6:40 pm
I'm definitely hearing some flanger or LFO modulated delay > 30 ms or so with high feedback. Maybe using an envelope follower or noise gate in the feedback loop. I had a korg sdd-3000 that could use envelope following as modulation source, and with a tight millisecond delay and high feedback it would sound like that.
Return to “Synth Noise”
