Volta + Logic 8 trig issue
Moderators: Kent, stretta
worker8
Post by worker8 » Sat Jun 26, 2010 5:26 am
Hi there,
When I use the trigger sequencer as a clock source, I got additional pulses. Like a random 32nd when I want a regular 16th.
I tried with different cables, but it doesn't fix it.
Anybody experienced the same quirk ?
I'm using an Ultralite mkIII.
w8
doctorvague
ole fuckity fuck
Re: Volta + Logic 8 trig issue
Post by doctorvague » Sat Jun 26, 2010 9:06 am
worker8 wrote:Hi there,
w8
Seems like I saw something similar when I first started using Volta.
Are you on the latest version of Volta?
Where is the duration set?
I set it at around 5 to get short pulses.
It defaults to 100 which is really dumb IMO.
If that doesn't help I'd contact MOTU about it.
worker8
Post by worker8 » Sat Jun 26, 2010 11:21 am
Well, I just checked : Volta 1.0.4.
I don't play such short pulses, mostly 50% long gates. I'll try to reduce to 5, just in case ...
I feel the opposite (everything was fine when I started) !
dogoftears
Puddle of Sealions
Post by dogoftears » Wed Feb 09, 2011 2:23 pm
ive experienced this. it plays the sequence normally and very very randomly on one of the loops might throw an extra gate in there. i usually like it, though i recognize it as a bug. i always pull the length param down to 90... i will try 5....
Return to “Volta”
