Mutable Instruments Frames resolution
denoise
Post by denoise » Mon Feb 06, 2017 5:42 pm
Hi,
Being Frames a digital module I expect to have a limited "resolution" in terms of values between frames. In that case I suppose that if the distance between frames is very small you should expect less interpolation points as when you have two frames at each spectrum of the knob. It's that true?
Do you have ever heard this theoretical digital aliasing?
what about audio rate modulation of the frame cv input? is this possible?
I doubt I would ever use VCOs as a modulation source, but that is something that could give me an idea of the DSP of the module.
thanks
Dcramer
Post by Dcramer » Mon Feb 06, 2017 10:51 pm
I believe there might be some kind of smoothing going on?
I've never heard any stepping between frames. :hmm:
akrylik
Post by akrylik » Mon Feb 06, 2017 10:55 pm
DMR
Post by DMR » Tue Feb 07, 2017 12:25 am
Keep in mind that Frames uses analog VCAs, it is just their amplitude that is modulated by a digital source. The specs pages notes that you can modulate up to 15KkHz: http://mutable-instruments.net/modules/ ... ifications
pichenettes
Re: Mutable Instruments Frames resolution
Post by pichenettes » Tue Feb 07, 2017 3:34 am
The ADC that reads the CV input has a resolution of 4096 steps. However, the values read by the ADC are processed by a digital lowpass filter, which means that the module will not abruptly step when the CV jumps from one ADC code to the other.
denoise
Post by denoise » Mon Feb 13, 2017 10:45 am
thanks! very good and informative answer.
Frames is the next one in my list.
FlangerMagazine
Post by FlangerMagazine » Sun Feb 19, 2017 10:22 am
Been on the fence about Frames for a while. Still haven't purchased.... mostly I realized that my hesitation is with that huge knob. It's so huge. Would be the largest knob on my set up BY FAR. Its just so big.
Xtheunknown
Post by Xtheunknown » Thu May 25, 2017 8:10 pm
FlangerMagazine wrote:Been on the fence about Frames for a while. Still haven't purchased.... mostly I realized that my hesitation is with that huge knob. It's so huge. Would be the largest knob on my set up BY FAR. Its just so big.
I initially felt that way about Warps. As it turns out, I actually like it!
Dcramer
Post by Dcramer » Thu May 25, 2017 11:08 pm
FlangerMagazine wrote:It's so huge. Would be the largest knob on my set up BY FAR. Its just so big.
Wait'll it gets hard...
. :lolspew:
DonKartofflo
The knob-twisting Hive Mind
Post by DonKartofflo » Fri May 26, 2017 5:43 am
Dont be shy, just put it in your rack gently and slowly
Nelson Baboon wrote:Beware of people who tell you to smile.
FS:
Mutable Instruments Tides 1 120€
Addac sys 12U powered frame 200€
