Show us your DIY MMModules...
Dedicated forum for the MMM synth modules, both production and DIY units.
Moderators: Kent, mmm
Adam-V
Count Modula
Post by Adam-V » Sun Apr 18, 2010 7:27 am
Here's my first one:
Frac 4x Gate Delay
Adam-V
Luka
Post by Luka » Sun Apr 18, 2010 7:32 am
mmm
yummm!
Post by mmm » Sun Apr 18, 2010 8:14 pm
That's just too cool, guys :guinness:
Keep sharing, this is fun.
G
Adam-V
Count Modula
Post by Adam-V » Thu Apr 22, 2010 7:13 am
Frac Voltage Controlled Mixer
Adam-V
werock
Post by werock » Thu Apr 22, 2010 8:05 am
:tu: Hmmm, that's given me an idea...
sandyb
Post by sandyb » Thu Apr 22, 2010 3:31 pm
good work Adam and Luka.
i'm planning a modcan a series panel with two vc dual lfos when they're done. i've also got an amplitude follower but haven't decided exactly what i'm doing with that yet. i might do it in a standalone box or maybe something a bit different. hmm...
BugBrand
Knowledge of Bugs
Post by BugBrand » Fri Apr 23, 2010 4:19 am
Frac love and banana love ---- I like 'em!
They all look like fantastically useful modules -- especially liking the look of the Quad Gate Delay -- yum!
Adam-V
Count Modula
Post by Adam-V » Mon Apr 26, 2010 4:49 am
And one more!
Adam-V
Scottzilla
Post by Scottzilla » Wed Apr 28, 2010 11:41 pm
Very nice! :yay:
qu.one
hypnotic and sanctified
Post by qu.one » Mon Jun 21, 2010 9:13 pm
really bad pic, but i squeezed the VCF and AF1 each on a 6HP euro panel width. i wanted to try and keep the MINI part of MMM alive in euro.
panels are etched opaque black acrylic. (with finger grease on them)
knobs are temp and i haven't installed the LEDs for the AF1, but you get the idea. im still trying to figure out what knobs - they need to be small.
i was just happy i finally had time to wire it up...
the only thing is that bandpass on the VCF is noticeably lower in audio level: see here for audio example.
mmm
yummm!
Post by mmm » Mon Jun 21, 2010 10:48 pm
I like the finger grease :eek:
Adam-V
Count Modula
Post by Adam-V » Mon Jun 21, 2010 10:56 pm
Finger grease AND big knobs -a winning combination!
Do you get much flex on the acrylic panels?
Adam-V
qu.one
Post by qu.one » Tue Jun 22, 2010 11:10 am
Luka wrote:Image
this is gorgeous btw...
BananaPlug
Post by BananaPlug » Tue Jun 22, 2010 10:39 pm
Here's my Squiggletronics edition of the MMM State Variable Filter! Works great!
I added a 2nd CV input and an attenuator on the audio input. Getting this into one frac unit with 16mm Alpha pots was a tight squeeze. The skinny Davies knob kock offs make it easy to use. The jacks are Serge color code because that's how I do all my 3u banana conversions
Blue acrylic panel from Pro-Modular with a bit of white spray paint.
...done up in blue print blue, sure looks good on you... :banana:
Ooops. Those are gifs. I'll fix it later. :doh:
Cybananna
Funniest Guy
Post by Cybananna » Tue Jun 22, 2010 10:48 pm
those all look great!
qu.one
Post by qu.one » Wed Jun 23, 2010 6:42 am
WOW! BananaPlug, your panel assembled came out GREAT!
qu.one
Post by qu.one » Fri Jun 25, 2010 8:44 am
WAY better with these knobs.
Luka
Post by Luka » Fri Jun 25, 2010 8:54 am
the davis touch :)
looks awesome stephen
BananaPlug
Super dense frac build of MMM VC Mixer
Post by BananaPlug » Sun Sep 05, 2010 5:18 pm
Here's my Squiggletronics edition of the MMM VC Mixer!
This is now the output module for my small Frankensynth (about 19" square). :banana:
It was not easy cramming this into a 1.5" wide frac module! If I'd done something like wire all the pots backwards I would have been really pissed.
The four pots are pull pots. :boat:
Pull the pot and a 5V source is substituted for the signal from that channel's CV input jack. This makes it behave exactly like a channel of a manual mixer. The little hole above the output jack is a recessed mini jack, same signal.
Panel laser cut by Pro-Modular just like the filter a few posts back.
Adam-V
Count Modula
Post by Adam-V » Sun Sep 05, 2010 7:04 pm
Nice one. I thought I was good at squeezing functionality into small spaces!
Adam-V
pugix
Re: Super dense frac build of MMM VC Mixer
Post by pugix » Sun Sep 05, 2010 8:25 pm
BananaPlug wrote: The four pots are pull pots. :boat:
I've been looking for pull-switch pots. Got a part number?
Thanks,
Richard
http://www.pugix.com
BananaPlug
Post by BananaPlug » Sun Sep 05, 2010 8:34 pm
qu.one
Post by qu.one » Sun Sep 05, 2010 8:52 pm
Bananaplug stuff looks great. Classy all the way.
pugix
Post by pugix » Mon Sep 06, 2010 6:09 pm
BananaPlug wrote:I buy them from Smallbear :wookie:
http://www.smallbearelec.com/Detail.bok?no=619
Perfect! :nana:
This will work great with the Mattson Quad EG I am building. I'm going to use the pull pots to switch between AD and AR mode.
Thanks,
Richard
goiks
Hardest Tryer
Post by goiks » Thu Sep 09, 2010 12:15 pm
an old and crappy pic, sorry!Image
Return to “Mattson Mini Modular”
