[IN STOCK] L-1 XLR Balanced Outputs - Eurorack kit / module.
L-1
Post by L-1 » Sun Sep 02, 2018 8:01 am
I made XLR Balanced Stereo Output -- Eurorack kit / module.
Based on THAT1646 Balanced Line Driver.
All details please read on my site: http://l-1.su/XLRout.html
Module:
Kit:
Jarno
Post by Jarno » Sun Sep 02, 2018 9:34 am
Schematic? I see you have 10uF on the board next to the balanced out drivers, but those should be 10uF bipolar caps, preferrably good ones (if they are the caps in the sense lines).
L-1
Post by L-1 » Sun Sep 02, 2018 9:52 am
10uF capacitors must be non-polarized according to the THAT1646 datasheet.
L-1
Post by L-1 » Sun Sep 02, 2018 9:53 am
Offset removing capacitors are 47uF electrolyths. (at the top of the board).
Jarno
Post by Jarno » Mon Sep 03, 2018 2:47 am
It's easier if you just post your schematic, not the one from the datasheet, not sure why this is not done more often.
You recreate a schematic first, before laying out a board right?
But, if I understand correctly, your board has 47uF BP in the sense lines of that IC?
Or are they indeed those 10uF SMT caps (which could work as well, I suppose)?
Also, there are a few pin compatible alternatives for 1646, and not all of those need the caps in the sense lines, I included them in my builds, figuring I could bypass them if not needed. Same goes for resistors in series with the outputs and to ground. These help in making sure the output IC "sees" about 600r, which is it's intended use, in practice, most inputs have a much higher input impedance these days.
By the way, not sure if anyone knows a solution, but these balanced line driver IC's do have a habit of dying if someone leaves phantom power on. I wonder how to solve this, I hope the series resistors I added help in this regard (add zener diodes on outputs, maybe?).
L-1
Post by L-1 » Mon Sep 03, 2018 6:01 am
10uF SMT are in sense lines.
47uF polarized electrolyths are at the input.
Diodes are protection against phantom power.
Schematic is here:
Jarno
Post by Jarno » Mon Sep 03, 2018 6:31 am
Ah, now I understand, looks good. I think you will need a return path to ground somewhere between that DC blocking cap on the input and the input of the driver IC though, but maybe someone more knowledgeable can chime in.
Nifty way of compensating for differences in component height too.
L-1
Post by L-1 » Mon Sep 03, 2018 9:48 am
I experimented with isolating transformers.
Wanted to make a possibility to optional install them.
I used hi-quality Neutrik NTL-1.
But I found no advantage of using them at the output against ground-loop hum.
Because there no hum if to use a single case and PSU.
A 100Hz ground-loop hum appears if to connect another case with separate PSU.
So I decided to make that possibility to install optional isolating transformer at the input.
I plan to make XLR inputs module where will be a transformer option. But need to make an experiment how it will be effective though.
Jarno
Post by Jarno » Tue Sep 04, 2018 2:08 am
Yes, transformers FTW, I also made a few balanced outputs using transformers, but I am using cheap ones, to get some colour (Edcor), you need to push them a little bit :D
For inputs, I think you are right, good transformers are better, maybe a microphone preamp based on API or Neve preamps? Voltages aren't that different for API (Neve is single ended PSU, at least the older class A stuff).
mentalu
Post by mentalu » Thu Sep 06, 2018 8:21 pm
Excuse the newbie question but why two inputs?
khakifridge
Post by khakifridge » Fri Sep 07, 2018 4:22 am
mentalu wrote:Excuse the newbie question but why two inputs?
And shouldn't there be a couple of resistors on these to stop two connected inputs fighting?
xenosapien
Post by xenosapien » Fri Sep 07, 2018 4:49 am
I think that these are not supposed to be two Inputs, but an Input multed through so you can take the signal OUT again?
for example you could route the signals to this output module, take the "through" multed signals and route them to a headphone amp module?
that would explain why there is no circuitry to mix these together or prevent them from "fighting" ;)
may you live in interesting times.
L-1
Post by L-1 » Fri Sep 07, 2018 7:26 am
xenosapien
You are right. These are multiples to use a signal further. Not two separate inputs.
For example I use two XLR out modules - one for a speakers, another for record, and further into Phones module.
megaohm
Post by megaohm » Fri Sep 07, 2018 8:44 am
Jarno wrote: By the way, not sure if anyone knows a solution, but these balanced line driver IC's do have a habit of dying if someone leaves phantom power on. I wonder how to solve this, I hope the series resistors I added help in this regard (add zener diodes on outputs, maybe?).
One power diode (1N4004?) to each rail for each of the outputs.
So, four total output.
Details are in the THAT 1606 / 1646 data sheet.
www.MegaOhmAudio.com
Will work for pistachios
L-1
Post by L-1 » Fri Sep 07, 2018 8:50 am
Yes, there made this way, in the module.
Dogma
Post by Dogma » Sat Sep 08, 2018 1:35 am
L-1 wrote:I experimented with isolating transformers.
This is exactly what im looking for - i was going to grab a Mannequins RIP but they sold out in about 2 seconds
Anyways this is the transformer id like to use cinemag cm-dbx-pc
Is this possible?
look up!
mentalu
Post by mentalu » Wed Sep 12, 2018 9:03 am
L-1 wrote:xenosapien
AHHH I got it. Great feature. Thanks for the explanation!
