I really like your combination of colors. The woodwork also looks like a perfect job.ElSmurf wrote:I decided to call it a day and close her up. She's fully functional and sounds right. Time to make some music!
Presenting: Crowminius
- Troubleshooter
- khakifridge
- Veteran Wiggler
Thank you for the kind works. Pretty happy with the woodwork myself. It says a lot about the ingenuity of the original mini front panel design to see it work so well in negative colors. This is just inkjet paper on acrylic, it was much cheaper to do it this way, and print black on white, than to get a metal custom panel made. If I ever do decide to get one (and buy the right size knobs...) I'll still go for this color scheme, cause I love it.
Re: Presenting: Crowminius
as the euro build seems to be quite similar to the normal one I will write here in the hope anyone answers.
( dedicated euro schematics and any kind of silkscreen documentation
would be very helpful at this point!!!!!, maybe oldcrow reads this, has a good day and wants to help.)
I am about debugging now. I focus on the oscillator board first I did a mistake and swapped one tl072 the wrong way around after I found out I had the
voltages of -10v and +10v at the ref points on the board.now ia facing a complete dead behavior of noise and all the oscillators' tried to scope any sign of life in the lm 3046. nothing there. could it be possible that I damaged all the transistors on the board by swiping on tl072 ic the wrong way around?
any help appreciated
cheers
s
I hope anyone reads this:
I figured out that I have a very low oscillation on all three oscillators. the highest frequency I am able to generate is 8 hz. I guess I have a wrong resistor value somewhere in there or a wrong cap. anyone has a hint.? all the waves are there if I switch between all of them but as I said very very slow.
- Troubleshooter
Hi, I would start looking at the components around the core's 3046. Maby you made a decimal mistake on all 3. Also look at the control voltage driving all 3 VCO's. A good visual inspection usually gets you there.
If I remember correctly, there were two options for tempco's, you have probably used the wrong combination. 10x off scale thing.
so two of the there are running now somehow but very quirky, the octave switch won't let me go higher than 250hz at 8'. I did use 1k tempcos with the right resi values, as those are suggested in the euro build. Osc 2 still is so low frequent that I can see the frequency on my scope only if I turn up the time to at least one second. I narrowed the problem down to LM 348 IC2. i can't se any change on leg 5, 12 and 10 when I turn the oct switch. even when they should have ground in LO position the do not change their value. that's definitely wrong. weird is tho that I can hear a frequency change when I switch between lo and 8‘ above as I said nothing happens. also not right seems that I do not have any change in pitch if put in a cv at the cv in.
thx for your help anyway
i just found out all the legs of lm348 are differntly pinned out in the euro version than in the schematics. eieiei
this doesnt make it easier to debugg. @oldcrow it would be so helpful to have dedicated eurorack schematics or at leaste eagle images of the boards.
Such i tight project and bearly any information on the Hostboard A.
For the 2N3392 the schematics says 'Selected' does that mean the Hfe?
also Is it necessary to Match the T23 and T24 ?
I am almost done everything works now. except I can't tune oscillator 1 as the scale trimpot doesn't do anything, ( on osc2 and 3 it works)
and my oscillator 2 is quite far down in pitch what doesn't seem right even without calibration.
have to check now R17 and r21 I guess for the scale on osc1. any hints tho.
i do have perfect cv tracking on all 3 oscillators.
all in all iam very happy with the flexibility in sound of this little beauty
any calibration experiences are very welcome.
also one question why is R13 different to R93 and R53.
cheers S
cheers S
Done it was a wrong resi. juhuuu.now i can tune that little fella.
i am wrapping my head around this thing right now. the glide circuit currently pulls down all my there oscillators in pitch. I narrowed it down to ic 21 ( in the schematics the pinout is switched as on the board) on leg 3 (schem.5)I do have without anything plugged into the jack cv in, 0 voltage but still the opamp starts generating voltages on leg 1 and 2 this seems not right to me. it has to do with the switch in the jack wich is connected to the clubs on the distroboards, so nothing is connected. if I use ground instead of the cv distroboard connection the circuit gets stable. if I plug in something into the cvin jack it also is stable.
thx for anything helping understanding what's going on here.
cheers s
i am building the euroversion.
cheers s
Hi Schanke,
I am also currently building the Eurorack version from ModularAddict and completed Module A. All your tips during your build issues were really helpful, so thank you so much! I also had a problem with a too low pitch (only heard clicking) which you had as well, so thanks for providing some input on where to look! I could narrow it down to not having any -5V to generate the correct pitch via IC2, turning out I was missing a solder point on one SMD resistor near the N5V 22uF capacitor.
Have you been able to solve your issue? If not, I saw I had the SMD diodes in the wrong direction at first, because I was not used to the SMD diodes and + - convention, maybe this is also happening in your case.
hi lytrix,
glad i could help. my biggest mistakes all came from placing smd resis the wrong way arround, caused by the super chaotic pcb design.
so thats really something to look at always in this project.!
i have to check what i exactly did, with the constant pitch drop. but i remember jumper to ground was the solution.
Yeah, I also did place 2 resistor smd’s 90 degrees in the wrong direction one time, but luckily the large spacing in between made me discover the mistake before continuing!
Outstanding support by the designer i have to say
Makes decision for other projects easy
That's the full width of SDIY, from untested schematics only to 24-7 chat service answering "which way the diode should be placed?". It really comes to how you describe "what SDIY is?". At the same time, I totally understand the frustrations for unfinished/non-supported projects, some even pretty expensive, but if you haven't put out any projects of your own design, you might not understand how enormously time-consuming this support can be. And, if you answer once to a question, it's 99,9% certain that more questions will follow. Some people just don't have the time for this in their lives. The question is would it be better for them not to share their projects in the first place? I don't think so.
I feel that everyone has the right to share their work as they want. The same goes for buying DIY projects. Peace.
- devinw1
Good thoughts Janne. My personal opinion is If something is shared among heads here at muffs or through some more bloggy type site, expect to figure out some shit on your own possibly. But if it's being sold by one of the big retailers like Thonk, SC, Etc, it should be at least minimally tested, have accurate BOMs/schematics and at least some minimal level of support. I mean, The retailers that have my stuff are always referring people to me with little questions. What do they tell people asking about projects where the designer is essentially MIA? "Sorry, you're on your own! Have fun figuring that out!". That would not make me happy at all. I'm an electronics nerd and enjoy solving problems, but if i pay for something from a retailer, I expect it to go together and not be a clusterfuck. Just my 2 cents!
