I am planning a build of the MFOS Ultimate+Expander and am reviewing all of the potential Mods and tweeks both on the MFOS site and on these forums.
One feature that I would like to implement is giving a CV input for the frequency of the LFO, but I have found nothing about such a modification.
I would imagine that a CV input could be added as a parallel circuit to the inverting input of U24-B, buffered with a 100k (?) resistor.
http://musicfromouterspace.com/analogsy ... _schem.pdf
Or maybe someone had already added this functionality to their build and can share their solution?
Thanks.
MFOS Ultimate LFO CV Input modification?
Moderators: Kent, dslocum, synthcube
Re: MFOS Ultimate LFO CV Input modification?
I haven't tried it, but that sounds reasonable. Perhaps just try and test it during the build - it's only a resistor, a bit of wirde and a jack after alljohnstilton wrote:I would imagine that a CV input could be added as a parallel circuit to the inverting input of U24-B, buffered with a 100k (?) resistor.
... why buy it for $100 when you can build it yourself for $150?
Update: It didn't work. Oh well.
Did you compare the circuit to the VCLFO module circuit on the MFOS site?
I bought the VCLFO and have just finished populating the Ultimate PCB, but haven't compared the two circuits.
I did compare them. They are significantly different
