Eurorack: better mallets with Rings
starthief
Post by starthief » Sun Apr 28, 2019 12:54 pm
Using the built-in exciter in Rings is... okay, but doesn't really sound like a nice xylophone/glockenspiel. This does, more or less:
Set up Rings in 4x polyphony (red LED) and modal mode (green). Tune frequency to about 12 o'clock, or possibly an octave up around 2; Structure at about 2, Brightness at about 1, Damping and Position about 12 o'clock.
Set up a triangle VCO with V/OCT controlled by keyboard, tuned about 2-3 octaves below Rings. Modulate the VCO frequency with a fast decay envelope (adjust the amount and rate to taste). Use a slower, but still fast-ish decay envelope for the VCA.
Run that into Rings' audio input and mult the same V/OCT into it.
Adjust everything to taste (particularly the pitch envelope amount/speed, Brightness and position). You may also want to mult V/OCT into the Brightness CV input and set the attenuverter negative, so that higher notes are not quite as piercing.
You can probably use a kick drum module in place of the triangle VCO. :mrgreen:
Audio:
http://starthief.net/stuff/rings_glockenspiel.wav
For comparison, here's how it sounds disconnecting the input to Rings and just using the default exciter:
http://starthief.net/stuff/rings_plain.wav
Hammered dulcimer variation:
Use a square VCO. Set Rings to sympathetic strings mode (yellow LED), Structure to 9 o'clock, Brightness 3 o'clock or higher, and Position about 3 o'clock. Give the pitch envelope just a taste of attack time. Plenty of stuff you can adjust about this too.
Audio:
http://starthief.net/stuff/hammered.wav
j_dowe
Post by j_dowe » Mon May 06, 2019 9:38 am
love the glockenspiel. i don't have this set up, but w/ the patch & tweak diagram and your notes i fully grasp it.
:yay:
Heliophile
Post by Heliophile » Wed May 22, 2019 4:13 pm
This is great, thanks for sharing!
Heliophile - synthpop
http://heliophile.bandcamp.com/
Zube
Post by Zube » Sun May 26, 2019 3:15 am
Awesome! Thanks for posting this. Love this new section
cg_funk
Post by cg_funk » Mon Jun 10, 2019 1:45 pm
This was cool to try.
I've been doing a similar trick with my guitar into Rings:
I put the guitar through an envelope follower.
Then I take the envelope and use that to open a VCA that sends the guitar to Rings. Set the VCA to slightly exponential, and just the plucking transients get sent to Rings input.
It's a trick I learned from Patch&Tweak called Peak Processing (p246).
bibleblack
Post by bibleblack » Thu Aug 08, 2019 4:34 am
Now just need to finish work so i can play
