'Teleplexer' patch with IFM modules and Mocante
Moderators: Kent, bartlebooth
I guess this should have been obvious to me, but I recently discovered that if you plug a patch cable into, say, a Sprott input, you can use the tip of the other end to probe the Mocante touch points and get a ridiculous range of possible audio outputs. The Mocante doesn't have to be plugged in to anything else. For added goodness, connect the Mocante's pitch input to one end of a patch cable and use the other end for FM by touching it to Mocante pads at the same time.
