ES-9 standalone summing?
Moderators: Kent, os
lackofair
Post by lackofair » Tue Jan 14, 2020 3:21 am
Hi there
I'm close to buy an Es-9 as my next audio interface solution. I love the flexibility it seems to have but I can't find an answer on how and if the balanced Jack's can work as a mixer out (simple summing would be enough) without computer connected? It would be wonderful to use it without computer every now and then...
Brs
os
Re: ES-9 standalone summing?
Post by os » Tue Jan 14, 2020 3:59 am
Yes. In the current firmware only 8 inputs can be summed to the outputs without a host computer, but that may change.
lackofair
Post by lackofair » Tue Jan 14, 2020 4:32 am
Great! And thx for being that quick!
That's pretty cool already. Are they summed as a standard or is it necessary to set this up and change it with the computer?
I'd like to use the Es-9 for both studio and live. So my dream would be to have all the channels in studio and as soon as I disconnect the computer they all go to thebalanced Jack's automatically.
os
Post by os » Tue Jan 14, 2020 4:35 am
You'd need to set it up that way with the config tool.
And currently you'd need to do that manually every time you wanted to go between the two setups.
lackofair
Post by lackofair » Tue Jan 14, 2020 4:46 am
i see. maybe a great addition for future firmware updates? to have 2 startup-states - one for connected computer and one without?
os
Post by os » Tue Jan 14, 2020 4:49 am
Indeed.
lackofair
Post by lackofair » Tue Jan 14, 2020 4:53 am
thx anyway for the help!
as soon as i find an availeable/stock es-9 in europe you'll have a new customer ;)
lackofair
Post by lackofair » Tue Jan 14, 2020 7:25 am
perfect!
bhenry1790
Post by bhenry1790 » Fri Jan 17, 2020 3:25 pm
+1 on easier standalone summing. My ES-9 arrived yesterday and I already find it indispensable!
tunelee
Post by tunelee » Mon Jan 20, 2020 4:01 pm
Didn't figure out how to set it with config tool, Try to set all input channels into Phones LR for standalone monitoring and saved to flash,not working..
os
Post by os » Tue Jan 21, 2020 3:35 am
Post a screenshot of the config tool.
lackofair
Post by lackofair » Fri Jan 24, 2020 8:12 am
got mine finally and it was actually easy to route after understanding the block principle.
2 more questions!
-does it makes sense to sum with f.e. -3dB per bus?
-is it possible to route all 14ins to the main jacks? the mixer block only has 8 slots right..?
thx again & ps. thx for the tip with signal sound, great and quick service
os
Post by os » Fri Jan 24, 2020 8:29 am
Setting the faders down will reduce the risk of clipping, sure.
Currently it's only possible to mix 8 inputs internally.
bmoussay
Post by bmoussay » Sat Jan 25, 2020 12:50 pm
Hello os,
Any chance to get a similar tool for the es-8 to provide internal and standalone summing? This would be great,
Best
B
os
Post by os » Sun Jan 26, 2020 4:39 am
Sorry, no.
TehLemur
Post by TehLemur » Sun Jan 26, 2020 10:38 am
Hi - I'm having a little trouble working out if the internal mixer will do what I need before I purchase: -
  • Is it possible to have inputs 1-8 monitored through the headphone output in real time (i.e. without latency)?
  • If so, can I pan some inputs individually to the centre of the stereo image, instead of them all being treated as stereo pairs, without affecting how they're recorded in the PC?
  • Can I have it set up this way, and still be able to hear the master output from the PC DAW in the headphone output when I play back?
os
Post by os » Mon Jan 27, 2020 3:13 am
Yes to all of that.
TehLemur
Post by TehLemur » Mon Jan 27, 2020 7:21 am
Awesome, thank you - you've just solved all my problems!
Return to “Expert Sleepers”
