PCBs as Front Panels ?
dKRelease
Re: Re:
Post by dKRelease » Sun Jan 12, 2020 5:42 pm
mrand wrote:
Sun Jan 12, 2020 3:17 pm
Lolo73 wrote:
Sun Jan 12, 2020 2:02 pm
I use 1.6 aluminium panels, made by PCBWay.
I'm curious, is 1.6mm aluminum panel more rigid than 1.6mm PCB with full "ground plane" on the backside? Wondering if anyone has had a chance to do a fair comparison.
Yeah it’s definitely more rigid. I think most euro size aluminium panels are 2mm but the 1.6mm are suffice providing your panels aren’t too big. FWIW, ground plane won’t add anything to rigidity as it’s something like 0.03mm thick.
mrand
Re: Re:
Post by mrand » Sun Jan 12, 2020 5:51 pm
Surprisingly, it does! Not as much as +0.4mm PCB material, I'm sure, but I've got the same sizes of each to compare (with and without ground plane), and the difference is quite easy to feel. I never would have guessed it would make a difference. I only ordered the ground plane because I thought it would look nice, but the added rigidity was a welcome accident!
--ssdp--
Lolo73
Re: Re:
Post by Lolo73 » Mon Jan 13, 2020 4:51 am
My largest panel measures 20 hp (see photo) and, even with 1.6 mm aluminum full of holes, the panel is very rigid. You have to force a lot to bend it! So I don't think we need something stronger.
smrl
Re: PCBs as Front Panels ?
Post by smrl » Mon Jan 13, 2020 5:24 am
FetidEye wrote:
Sat Jan 11, 2020 4:03 pm
I have yet to find out how to make oval holes and milled cutouts (for sliders and displays for example. If anyone has tips on that, please :)
I don't know specifically about how to do this in Eagle. But in KiCAD I've had luck specifying slots as custom footprints, and using oval hole shapes to specify dimensions of routes.
Here's an example of a footprint I just used to make a route with "mousebites" to separate two panels in a design
mrand
Post by mrand » Mon Jan 13, 2020 2:27 pm
I see so many builders here... is there a network to trade complete, homemade modules? I know about the trades thread, but it seems more for parts and unbuilt kits, etc. What about a place to trade 1:1 finished modules? Must be loads of folks like me who order 5 units from china but only need 2 or 3.
--ssdp--
Lolo73
Post by Lolo73 » Tue Jan 14, 2020 4:35 am
I could even say : Must be loads of folks like me who order 10 units from china but only need 1 :hihi:
FetidEye
demonic space drone
Post by FetidEye » Tue Jan 14, 2020 9:56 am
I think most of us build the amount that we need and then trade the bare pcb's and panels.
those turn up in the trade thread you mentioned, or are traded with local friends?
I don't think a lot a people build all their pcb's and then trade them. too much work?
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Jan 14, 2020 11:47 am
more money in my pocket. I always build 10 modules and sell 8. then I sell the other 2 for food. then I get paid from my job and I rinse repeat. this is why my rack is usually empty.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Jan 14, 2020 11:54 am
in eagle you just put it in the milling layer. your PCB fab should see it. if you need through hole plating on your slots that is a bit more complicated. it requires a custom part. some PCB fabs are smarter than others. you may also need to add the outline of your milling stuff to the dimension layer. your fab actually has specs on min drill and min slot. read them. everyone wants the smallest possible milling bit. for your LCD cutout you have square inside corners. this is possible but you may end up paying a lot more for that feature. if you require square inside corners you must communicate with the factory that that is your requirement. or just submit the gerbers and they will either reject, modify, ask, or make a bad PCB you can't use.
mrand
Post by mrand » Tue Jan 14, 2020 1:08 pm
ha, yeah no doubt. I was very happy when some PCB fab houses dropped their minimum to 5.
Isn't it only 20% slower to build two units than one? So if we could trade the extra, then we start to maximize our return.
--ssdp--
Altitude909
Post by Altitude909 » Sun Jan 19, 2020 8:45 am
um, I say its twice as long to build 2 instead of one and then why trade it at cost when you can sell it at a mark up and then just build the other module yourself
EATyourGUITAR
has no life
Post by EATyourGUITAR » Tue Jan 21, 2020 11:35 am
PCB cart sent me an email
For your order (EDIT)xxxxxxxxx, part xxxxxxxxx, there is large PTH hole, we need to take it as edge-plating and charge you the extra cost of 30 USD.
We have send the paypal link of $30 to you on Jan 13, have you recieved it? We will resend the paypal link to you later today, please kindly check and make the payment asap. Or, you could pay $30 to our PayPal account"payment@pcbcart.com" and note down the order number xxxxxxxx.
The order was already finished and ready to be shipped, we are waiting for your payment to release the order to you. Kindly note we are taking the CNY holiday from Jan 23.
so I wasted a week because they never emailed me. then they leave for a week. but most important of all. we learned that you should tell them DO NOT PLATE holes larger than 4mm diameter. I already put a note "do not print batch number on PCB".
also I have a coupon code for %10
10% discount, up to $100 OFF. Coupon code: 2020SFP, valid from Jan 20th to Jan 31st, 2020.
Troubleshooter
Post by Troubleshooter » Mon Jan 27, 2020 5:35 am
I recently used the x0xb0x DXF files and edited them in AutoCAD. Then I imported them in EasyEDA and edited some more. This is the result. Still waiting for the boards to arrive from JLCPCB.
guest
Post by guest » Mon Jan 27, 2020 10:58 am
that looks really good! is that going to be PCB or aluminum PCB?
openmusiclabs.com
Troubleshooter
Post by Troubleshooter » Mon Jan 27, 2020 1:03 pm
Ordered regular PCB material. It should be stiff enough. Lets hope so....
brycecake
Post by brycecake » Wed Jan 29, 2020 4:34 am
mrand wrote:
Sat Jan 11, 2020 3:24 pm
There must be others who have arrived at the same conclusion to use 10x10cm panels?
DAAAAANG you just changed the game.
I didn't realize it would be so much cheaper but yeah, like $5 for 5 on PCBWay, $2 on JLC, that's nuts. That's practically free lol
Maybe I'm just getting excited, but I think synth diy-ers should highly consider this format.
Thanks for sharing, looks great!
cackland
Post by cackland » Wed Jan 29, 2020 12:42 pm
Don't forget shipping costs. That's mainly your cost in smaller quantities.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Wed Jan 29, 2020 9:41 pm
it worked
mrand
Post by mrand » Thu Jan 30, 2020 6:38 pm
Well, at least it's a nice prototyping format!
If you want files for panels or anything, LMK.
--ssdp--
rsholmes
Post by rsholmes » Sun Feb 09, 2020 8:34 pm
FWIW here are a couple photos of a recent JLCPCB panel. I designed a format dedicated to maximizing the low-cost, 10x10cm PCB offerings. It's a very cost effective solution, especially now that the minimum order is down to 5 units. At standard 1.6mm thickness, there is no rigidity problem.
If you haven't come up with a name for this format yet, may I propose "Sinorack"? :mrgreen:
Post by KSS » Tue Feb 11, 2020 12:11 am
Many PAIA 2700 and 4700 modules are 4x4". 2wx4"h is their smallest module.
What's .060" between frends?
mrand
Post by mrand » Tue Feb 11, 2020 12:45 am
Sinorack. I like how it sounds, is there a meaning I'm missing?
I've been informally referring to it as the SSDP format, but I think since it's a very DIY-rooted format, it can have many names :)
I'll leave you to guess the acronym.
I definitely was thinking of PAIA with this format!
--ssdp--
040B
Post by 040B » Tue Feb 11, 2020 1:58 pm
I’ve been considering this too for my diy plan. Square tiles can look pretty nice in a suitable rack.
Do back and front silk screening so you can use panels for different builds. For extra extra cheapness.
rsholmes
Post by rsholmes » Wed Feb 12, 2020 6:55 pm
https://www.merriam-webster.com/dictionary/Sino-
rsholmes
Post by rsholmes » Sat Feb 15, 2020 8:03 pm
This is an interesting discussion, but I'm still a little hazy on some aspects of it. A "worked example" would help. Would anyone be willing to post a KiCad pcb file for a typical, basic front panel?
