Site Migration Completed
Important announcements about the forum and other Muffwiggler.com sites.
Moderators: lisa, Kent, Joe.
rec.Koner
Re: Site Migration Completed
Post by rec.Koner » Fri Jan 17, 2020 11:18 am
Thanks, i'll try. I understand, that trick works due to "Search within - First post of topics only" part? Interesting.
rec.Koner
Post by rec.Koner » Tue Jan 21, 2020 11:10 am
"Active topics" brings me blank page, does it work for anyone?
mskala
Post by mskala » Tue Jan 21, 2020 11:32 am
Not for me, it just says "No suitable matches were found."
rec.Koner
Post by rec.Koner » Tue Jan 21, 2020 12:02 pm
You right, it says such words. I haven't noticed.
I like "Active topics" on forums because it doesn't interfere with "new topics/posts from visit"
Licudi
Post by Licudi » Fri Jan 24, 2020 5:47 am
Apologies if this is the wrong thread to raise this, but the availability of the Search function is limited now. Is this a byproduct of making it available to non-members (you used to have to login to use it), or is there some other reason?
Flatscan
The Caretaker
Post by Flatscan » Sun Jan 26, 2020 12:15 am
Could you elaborate? I believe the search algorithm changed with the upgrade, but it should be available as normal.
Licudi
Post by Licudi » Sun Jan 26, 2020 3:13 am
Often I get a 'Search not available. Try again in -x- seconds' message.
Licudi
Post by Licudi » Sun Jan 26, 2020 3:22 am
BTW, is it possible to add 'Disable BBCode' tickbox to this thread so I can quote properly. Also the edit function.
Prunesquallor
Post by Prunesquallor » Sun Jan 26, 2020 2:03 pm
+1
This comes up a lot.
Flatscan
The Caretaker
Post by Flatscan » Sun Jan 26, 2020 9:52 pm
How frequently are you trying to to search?
The server is set to limit searches to once every 10 seconds for logged in users, or once every 30 seconds for guests. These are the defaults, and seemed reasonable to me.
The Disable BBCode option is there for me, so I'm guessing it's disabled across the whole Announcements forum for regular users. I'll check with the other Admins to see if that's intentional.
Licudi
Post by Licudi » Mon Jan 27, 2020 3:09 am
I tend to use Muffs like a library; most of my visits here begin with a search for information, but recently that has been more difficult. Therefore I wondered whether there was a problem that had passed unnoticed or a delberate decision to limit searches following the site migration. Thanks for the answer.
jonne74
Post by jonne74 » Mon Jan 27, 2020 5:09 am
I keep getting logged out on my phone. Firefox on iphone xr. Last time it was something with http or https. Is it a settings thing?
Licudi
Post by Licudi » Mon Jan 27, 2020 9:00 am
Well my first search of the day resulted in this. Maybe the performance of the search facility is not as advertised.
[attachment=0]Screen Shot 2020-01-27 at 13.57.52.png[/attachment]
rec.Koner
Post by rec.Koner » Mon Jan 27, 2020 9:18 am
Weird, i usually get this message if i search again after previous search.
However...
If i'm not mistaken, there is a thing that makes me disappointed - it's well known "bug" with search, when it treats browsing pages of results as separate search, which is very annoying, to say mildly. Like, it allows you to see page 1 of results, but you have to wait if you switch to 2,3,4, etc. pages of results of search.
Flatscan
The Caretaker
Post by Flatscan » Mon Jan 27, 2020 1:08 pm
I've lowered the logged in user search time limit to just a few seconds. Hopefully that will help and not murder the server.
strettara
mufferthucker
Post by strettara » Wed Feb 12, 2020 1:34 am
Flatscan: just wanted to say that after nearly two months to acclimatise to the new look and system, I love what you've done. The forum is much more usable and the layout is clear and easy to navigate. Even avatars on the right looks normal to me now! Thanks for doing a great job.
nangu
Post by nangu » Wed Feb 12, 2020 1:42 am
Avatars on the right that happen to be an obnoxiously strobing dickbutt will never look normal to me. :)
strettara
mufferthucker
Post by strettara » Wed Feb 12, 2020 4:38 am
Oh now you're just hurting my feelings.
nangu
Post by nangu » Wed Feb 12, 2020 5:24 am
Maybe you can work through your bad feels by kicking my ass at chess yet again. I’m still here.. :)
Flatscan
The Caretaker
Post by Flatscan » Wed Feb 12, 2020 12:50 pm
I appreciate hearing that. Thank you.
"Avatars on the left" is still on my list of things I'd like to add support for. Maybe after the v3.3 upgrade.
ChrisR
Post by ChrisR » Thu Feb 13, 2020 6:22 pm
For "Avatars on the left" the CSS part could be as easy as this:
.postprofile {
border-width: 0 1px 0 0;
float: left;
.postbody {
float: right;
I've only tried this with Firefox's Element Inspector but at first glance it seems to do the job.
The question maybe is how to make this individually selectable for each user.
gryfon1
The Chaos Acres Home for Electrons
Post by gryfon1 » Thu Feb 13, 2020 6:38 pm
Okay, I know nothing about the software being used, but conceptually, all that’s needed is a Boolean flag for right yes/no. Then a global check when selecting and rendering the CSS. Can that be done?
Flatscan
The Caretaker
Post by Flatscan » Sat Feb 15, 2020 12:52 am
.postprofile {
float: left;
.postbody {
float: right;
Sure, If I want to set that for everyone.
But most users are happy with the avatars being on the right. Forcing everyone to have them on the left is no better than forcing everyone to have them on the right.
You're not wrong, but there would have to be a place for users to set that boolean flag and somewhere for me to store it. I'm not about to start adding columns or tables to the database without a much deeper understanding of how it's all handle.
I know nothing about phpBB extension development. Maybe I'll have to learn some. From what I know right now, the easiest way to do this would be to add it as part of a new Theme/Style. But then everyone that wants left-side profiles would need to use that style, so I'd have to copy all the styles into left- and right-handed versions.
That just gets messy, quickly. Not scalable or easily maintained.
Post by 01235813 » Sun Feb 16, 2020 2:00 am
Hey Flatscan, this place is awesome! The new forum upgrade has been a huge step forward. Thank you for your efforts.
I think that we are all creatures of habit. Avatars on the left, avatars on the right.. you're never going to be able to satisfy the needs of all users. I think that with this here thread, your willingness to discuss and the issue-tracker, we are on the best way steering in direction of general consensus.
I personally find flashing dickbutts on the right less offensive than on the left.
khakifridge
Post by khakifridge » Mon Feb 17, 2020 12:21 pm
I've had the opportunity (aka necessity) to read the forum on my phone while on vacation this week. It's working seamlessly on the smaller platform too. So thanks again for your efforts, Rob.
Return to “Announcements - Please read!”
