Cloney VCS3 Clone Builders?
alka
Re: Cloney VCS3 Clone Builders?
Post by alka » Tue Jan 07, 2020 9:53 am
Portabella wrote:
Mon Jan 06, 2020 6:29 pm
alka wrote:
Mon Jan 06, 2020 10:33 am
In the end after meticulously building I had an issue that was only tracked down by Derek that involved one bad transistor in the PSU section of Board A.
How did Derek track it down? Was it sending tons of emails back and forth or did you actually send him your unit?
Further I am curious of the faulty transistor was delivered faulty or if you actually fried it while soldering?
I'm extremely careful soldering so it must have been a dud transistor or maybe even out of spec. As one wiggler noted, these units are very particular regarding components and subtle spec variations. But yes in the end I was stumped and it was easier to just send the populated boards to Derek. He was very prompt and communicative as he tested and noted that it was the hardest problem to find in all his days working with these so I didn't feel too bad :razz:
the Colour of Terrible Crystal out on Vince Clarke's VeryRecords
http://veryrecords.com/portfolio-item/a ... e-crystal/
j450nn014n
Re:
Post by j450nn014n » Sat Feb 01, 2020 9:50 am
Portabella wrote:
Sun Nov 17, 2019 11:05 am
Yes, I am buildidng one too. Got all parts now besides the matrix.
There seem to be not too many people around here doing it
There's a facebook builders group up now... I heard the matrix are still on hold. did you get yours?
Autistic. I like making noises at my workplace. I usually end up breaking something.
j450nn014n
Re:
Post by j450nn014n » Sat Feb 01, 2020 9:51 am
alka wrote:
Sun Nov 17, 2019 7:08 pm
I've built one. Will chime in with any tips if I can!
Thanks. I still wonder if I'm doing it right, but ok so far.
j450nn014n
Re:
Post by j450nn014n » Sat Feb 01, 2020 9:54 am
sanders wrote:
Wed Nov 20, 2019 7:36 pm
I'll be building a Cloney; probably won't start till I receive the Matrix.
I finished a Synthi a few years ago using Derek Revell's original boards(which took me almost a decade all told). It was a bear to finally get working properly, and I have issues with it to this day due to some inferior parts I elected to use (mainly the card connectors, but also the vernier dials and joystick).
If I could give myself some advice beyond that, I'd say spend as much time as needed to plan out the wiring paths so that they reproduce the neat tidy paths employed by EMS, use multicolored wires so it's easy to tell what's what (when you have a million wires all meeting up in one place.
I've been wondering myself why there isn't a Cloney topic here on Muffs yet. It should probably be started in the DIY section. There is a Derek Revell/Synthi topic there already, but I think a separate VCS3-type build topic is warranted.
That is exactly where I am now. Wiring. I have all the boards and PSU done, and am considering the wiring. The unshielded was pretty easy, though I should have left more slack. I'm keeping colours consistent and bundling things up with velcro (for the moment).
I'm thinking of doing all the 12/9/0V stuff in solid wire and bend it all to look sane and nice, but I'm not 100% sold on that one.
j450nn014n
Re:
Post by j450nn014n » Sat Feb 01, 2020 9:56 am
Portabella wrote:
Thu Nov 21, 2019 4:46 pm
So started building the Cloney today.. first steps.
It's a massive project, populating the PCBs and all the mechanic work is one thing but the wiring is extraordinary! Honestly, I underestimated all the work.
But the quality of parts, panels and the case is phenomenal.
Agreed. The wiring scared me the most so I've left it until last. I *think* I'm beginning to understand it. Have the non-shielded done which taught me a lot. Good luck!
j450nn014n
Re:
shoegazer86 wrote:
Thu Nov 28, 2019 8:58 am
I'm working on my own PCBs, which are period accurate copies of the originals. I grabbed a matrix from ebay a while back which got me into this mess to begin with...
That is beautiful!
j450nn014n
Post by j450nn014n » Sat Feb 01, 2020 9:59 am
LED-man wrote:
Mon Dec 23, 2019 5:49 am
I made a issue list on my website for the 2019 Cloney version.
Access is only possible with an account and for Cloney users.
https://www.dsl-man.de/display/DSO/Clon ... nd+support
I’ll give „edit“ permission on my page for every user, feel free to add known issues or other related infos.
delayed
Post by delayed » Sun Feb 02, 2020 9:11 pm
Is there a waiting list to get a kit?
Portabella
Post by Portabella » Tue Feb 11, 2020 11:02 am
hey fellow builders,
I have a question regarding thosee 4x 0.1 uF capacitors which seem to sit directly in the audio path of the filter.
probably this is a veery important part of how the filter will sound.
in my kit there were some very cheap and small ceramic capacitros.
does it make any sense to swap these out for better ones or maybe even some NOS capacitors to get a nice vintage sound?
and if so, what would you suggest? styroflex? polypropylene?
Post by KSS » Wed Feb 12, 2020 9:17 pm
Those *are* the same as the originals. If you want *this synth's* vintage sound,m just use them. After that, you're in virgin territory, so let the capacitor sound games begin!
FWIW, the ARP2500 1006 ladder filter also used similar ceramic disc caps. Nothing special about the caps in many minimoogs either.
So on the "vintage sound" question, I think you're ok using what you have.
cnicht
Post by cnicht » Thu Feb 13, 2020 3:47 am
Interesting discussions here about filter capacitors:
viewtopic.php?f=17&t=65022&start=650
Portabella
Post by Portabella » Thu Feb 13, 2020 4:55 am
Well pictured is an actual original EMS.. it was just meant to be symbolic.
In my clone I have very small ceramic caps like these:
Thanks for the head-up !
Thats an interesting read and interesting in general in terms of what I can mod in my clone :)
Thank you
j450nn014n
Post by j450nn014n » Tue Mar 03, 2020 2:55 pm
Unfortunately, there are no more Cloney kits available. I don't know who might be doing it now, if anyone.
