The 2020 Show Us Your DIY Builds Thread!
elmegil
Re: The 2020 Show Us Your DIY Builds Thread!
Post by elmegil » Thu Mar 19, 2020 1:52 pm
No worries about module depth there! :-D
cartertools
Post by cartertools » Thu Mar 19, 2020 2:33 pm
Yeah I do a lot of stripboard stuff and adapt MFOS, etc so the extra depth is handy. Plus it's stable and less likely to move, a less deep case gets stacked on top of it, and so on...
Peake
I'm in ur DIY. Filling cases with Buchla
Post by Peake » Thu Mar 19, 2020 6:05 pm
Roman 258 V3.0 with original transistor types, added linear/exponential FM switching, carbon film and carbon composition resistors in the waveshaper. Multi-turn trimpots for V/Octave, Linearity, and Heater.
This is not the place I'd imagined it to be.
forestcaver
Post by forestcaver » Fri Mar 20, 2020 10:40 am
Been busy building a small analog voice this year:
3d-printed case (46hp) with £7 dc power supply and bus board (meanwell dc-dc switcher - runs from 9-18v dc wall wart)
3340 vco (on-off-on switches on fm and sync)
3320 lpf (attenuverter on fm)
3320 hpf (attenuverter on fm)
lpg
3310 dual ASR
2164 Dual VCA (can chain an indefinite number together to create a huge vc-mixer/multi-channel vca) via jumpers on the back.
Headphone amp (1 ohm output impedance - can drive low impedance cans eg 32 ohm but has enough current to drive 600 ohm cans easily)
All with reverse polarity protection.
Ideas inspired from loads and loads of places !!!! (Acknowledgements in the schematics)
I plan on uploading the files to my github when I have cleaned them up.
forestcaver
Navs
Post by Navs » Wed Mar 25, 2020 3:42 pm
Little passive DIN Sync adapter/mult box. Write-up here:
https://navsmodularlab.blogspot.com/202 ... c-box.html
Jarno
Post by Jarno » Sat Mar 28, 2020 1:43 pm
011-modular_ajh_asr.jpg012-modular_ajh_asr.jpg013-modular_ajh_vca1.jpg014-modular_ajh_vca1.jpg015-modular_ajh_phones.jpg016-modular_ajh_phones.jpg
I've been ogling those Kassutronics ASR envelope generators, what do you think of them?
forestcaver
Post by forestcaver » Sat Mar 28, 2020 1:56 pm
No idea I’m afraid - I havent seen them!
Jarno
Post by Jarno » Sat Mar 28, 2020 3:24 pm
Oh, I figured that's what you built, which circuit or pcb did you use?
forestcaver
Post by forestcaver » Sat Mar 28, 2020 3:43 pm
They’re all mine.
audioCTRL
Post by audioCTRL » Sun Mar 29, 2020 5:41 am
I'm building these small standalone synth-modules.
Every module has its own build in psu and they are daisy chained with standard dc-dc jack cables.
vco - vco - filter - filter - format jumper/unity mixer
lfo - sequencer - usg - vca/mix - vca/mix
sequencer
Barcode
Post by Barcode » Sun Mar 29, 2020 10:49 am
I had a HexInverter Liquid HiHat board laying around so I designed a dual vca + decay envelope "extander". I call it the Liquid HiHat XL. The LHH voices are normalized to the external input switched jacks, so you can you can plug anything in and make it a "drum". The temporary panel finally arrived from Ponoko.... so here it is.
chrischn2000
Post by chrischn2000 » Sun Mar 29, 2020 11:26 am
Stay at home time is DIY time...
Had a Korg monotron DUO here and always thought that it sounds cool but can't be played seriously in a set. So why not put it in the rack?! It's a fairly easy build, all necessary solder points are there. And on top the housing fits perfectly into eurorack!
hox3d
Post by hox3d » Sun Mar 29, 2020 12:19 pm
Just finished this today, the boards arrived two days ago.
Can you guess what it is?
Matte-fueled habits
sduck
experimental use of gravity
Post by sduck » Mon Mar 30, 2020 8:46 pm
Ack, the attempted update last night screwed up the recently posted images here and elsewhere. Hopefully this will get fixed.
Anyway, I finished this -
forestcaver
Post by forestcaver » Wed Apr 01, 2020 8:09 am
Nice! The nuts look great... got a pcb and panel on the way - couldnt resist it - I really dont need another oscillator right now, but I’m a glutton for bling and it looks like fun....
roglok
Post by roglok » Wed Apr 01, 2020 8:42 am
that's cool. how is your typical DIN Sync input designed in terms of input protection? maybe an active solution clamping signals to 5V makes sense...
of course you can also use DIN Sync outputs to control your modular or sequencers / drum machines with trigger inputs. i built this, which works a treat: http://www.florian-anwander.de/a100/sync2clock/
soup
Post by soup » Thu Apr 02, 2020 1:02 pm
MFOS dual attack release in banana blacet drag. I tried out using black on white plexi for the first time and dig how it turned out...
roglok
Post by roglok » Thu Apr 02, 2020 3:43 pm
nice! i'm quite fond of that module. it's the third i've ever built and it sees a lot of use.
dot matrix madness
Post by dot matrix madness » Fri Apr 03, 2020 5:10 am
Modified TR-909 Handclap and Rimshot for Eurorack.
Mods for the Handclap are those of Colin Fraser plus a switch to change the noise source from
the digital 909 (from a separate module) to a 808-like noise transistor (sounds somewhat lower in pitch).
Furthermore a tune poti was added: The original R207 (150k) was replaced by a 500k lin poti
and a 2k resistor in series (or 1M lin poti and 1M resistor in parallel as realized here).
The remaining half of the LM13700 was used for a simple linear VCA. Thus the three extra jacks.
I've posted the Rimshot modification already in the DIY section.
Licenced to solder since 1993
slaughterhousesam
Post by slaughterhousesam » Sun Apr 05, 2020 4:49 pm
my celebratory corona-im-feckin-bored-and-going-super-ghetto contribution. mass recycled, shithouse black tape special lol :)
i kind of like it, think i might leave it this way as a commemorative special. anyway as its not obvious, its a toppo twf on the left and a haible tau on the right under the tape.
slaughterhousesam
Post by slaughterhousesam » Sun Apr 05, 2020 5:28 pm
when you dont have access to schaeffer panels and the like, all of a sudden you see the logic of the serge paperface graphic approach....aka the i-could-do-that-with-a-sharpie moment of clarity :)
smiler
Post by smiler » Mon Apr 06, 2020 5:09 am
Roni wrote:
Mon Jan 13, 2020 4:15 am
Making a few of these...
steviet
Post by steviet » Wed Apr 08, 2020 4:57 pm
Shamless self plug....
https://www.stevetravale.com/blog/
Check it out to see all my 2020 build diaries! (There's like 12 of them at this point, more to come!!)
Here is a picture of one so I'm not cheating this thread...
Sorry for the greasy flux finger covered panel :sstorm:
Soundcloud
bonzai
Post by bonzai » Thu Apr 09, 2020 1:15 pm
Done several diy PCB kits this year:
- Patching Panda Copycat and Petit Mix
- uJove
- Antumbra Cara
- and currently in the queue: Antumbra DVCA and STModular ADSR (still waiting for parts from Thonk though)
And a selfmade one: diy copy of Doepfer A182-2
