Gotharman's Little deFormer 3
gotharman
Re: Gotharman's Little deFormer 3
Post by gotharman » Sat May 16, 2020 4:55 am
Scories wrote:
Mon May 11, 2020 4:08 pm
Indeed, spelled like this : deFective
Indeed! Great idea :hihi:
gotharman
SPIKE the Percussionist wrote:
Wed May 13, 2020 4:53 pm
this is my 100th YouTube broadcast of Late Night Noiz For Late Night Fiends!
i posted this in the videosynth thread with a lot more info but wanted to link a bit of info here since this shows the LD3 being used as controller.
editing and implementing the CC control tracks is so easy!
LD3 was sending clock to video modular rig, switching video channels on a V8, controlling an ETC and an Entrancer.
i wanted to do something a bit over the top so i tried putting together as many sources as i reasonably could at this point in time.
14 video sources.
noiz and control provided by:
- Little Deformer 3
- Nava Extra 9
- norns x3 - Cheat Codes, Time Party, NC-01-Drone WRLDS
- Dark Energy
- Double Knot V2
GREAT NOIZ!!!
gotharman
Post by gotharman » Sat May 16, 2020 4:59 am
flx wrote:
Fri May 15, 2020 10:24 am
I was asked by a viewer to explain the Little deFormer 3's audio bus system, so I made a quick video walkthrough :)
This reminded me that I had wanted to ask for a setting in the BUS ENV menu that bypasses any bus volume modulation, so an option that keeps the Bus volume at the maximum (or at the BUS LEVEL value). Right now I can only select the bus' own follower envelope, a part envelope or follower x2 or x4. This means that there will always be some volume modulation when I want to use a bus follower. Or am I missing an option here?
Also, I think the touch screen button for BUS LEVELS should be called "Blv" and not "Flv", right?
Thank you very much for making yet another super cool video!
It's a great idea adding an "OFF" position on the ENV page, so it is possible to use the follower for modulation only. Will have a look at this.
When looking at the names of the BUS sub pages, I actually think that most of them look cryptical :hihi:
I will have a look at this for the forthcoming update too!
Fayette
Post by Fayette » Sat May 16, 2020 5:48 am
A Big yes to adding OFF as an option on the ENV page!
gotharman
Post by gotharman » Sat May 16, 2020 7:18 am
Okay, okay :)
It might even be possible to do some other fun stuff
flx
Post by flx » Sat May 16, 2020 9:47 am
OMG! Yes!!! Routing buses into other buses directly without the “output to input“ cable workaround would be super! :D
This would let one put an analog filter after insert FX or even on the “main output” bus.
You can also find and contact me here:
tuesdaynightmachines@gmail.com
YouTube
nightmachines.tv
Joakim
Post by Joakim » Sun May 17, 2020 9:21 am
Ha, I was going to ask if something like this would be possible. :)
On a related note, could an option be added to route external inputs to a pair of busses, like you can do with Parts? I've been achieving the same thing by splitting an external signal to two inputs and it would be nice to be able to to it in the LD3 itself.
Two reasons you might want to do this:
1. Feedback experiments. Route a signal from an external effect to two busses and send one of them back into the effect.
2. Use Bus Levels as aux sends to hardware effects. Send a signal from a Part (or two external inputs) to two busses and route one of them to an output/effect. This is quite flexible as you can end up with everything from a 100% effected signal to no effect and all ratios in between.
I'm sure there are many other things you could do too, especially if you can send busses to other busses!
meska
Post by meska » Sun May 17, 2020 10:25 am
agree 100% !!
tremblap wrote: In theory, there is no difference between theory and practice.
In practice, there is.
www.meska.fr
https://statikwave.bandcamp.com/
oneiric.tomb
Post by oneiric.tomb » Tue May 19, 2020 4:31 am
Is there a slew circuit/ filter in the delay algorythm ?
WTB:
Schippmann Omega Phi mk2
Cwejman BLD-2
Cwejman PH-8
gotharman
Post by gotharman » Tue May 19, 2020 10:30 am
You can insert a filter, and any other effect, in the delay feedback loop, by using an audio bus.
oneiric.tomb
Post by oneiric.tomb » Tue May 19, 2020 5:13 pm
Oh cool, i thought it was just the delay output, not in the actual feedback loop itself!
WTB:
Cwejman BLD-2
Cwejman PH-8
oneiric.tomb
Post by oneiric.tomb » Thu May 21, 2020 12:59 am
Is his filtering or inserting things into the feedback loop only possible on the output fx? for example if I want to smooth out the clicks in the delay on an insert effect with a filter is this possible? Thank you
WTB:
Cwejman BLD-2
Cwejman PH-8
oneiric.tomb
Post by oneiric.tomb » Fri May 22, 2020 2:33 am
Also apologies for the multiple posts, but the comparison chart for gotharman gear says that ring modulators are planned for the LD3, this is something that is quite high on my list of priorities i dont know about others here.
WTB:
Cwejman BLD-2
Cwejman PH-8
flx
Post by flx » Fri May 22, 2020 2:49 am
ring modulators
You might already be able to achieve some kind of audio rate amplitude modulation effects with the bus follower envelopes. Set a follower as a modulation source of a VCA’s level parameter. Can’t try it myself with my LD3 at the moment, but go ahead and see if you can come up with some cool sounds and report back :)
YouTube
nightmachines.tv
yorgos_zzz
Post by yorgos_zzz » Sun May 24, 2020 4:00 pm
I don't know if a facebook post is an adequate format to post music made with gotharman's little deformer 3, but at the moment that's the best i can do.
This is a track made exclusively with the little deformer 3, one take, no edits, no eq-ing, no mastering.
and yes, ld3 is a device with unbelievable capabilities.
gotharman
Post by gotharman » Mon May 25, 2020 12:02 pm
Really cool track! Thanks so much for sharing!
yorgos_zzz
Post by yorgos_zzz » Sat May 30, 2020 12:56 am
This is a track made with gotharman's little deformer 3, and combines morphing of the sequences together with some filter twiddling.
Electro-harmonix platform and RNC1773 were applied on the output.
I hope you enjoy!
gotharman
Post by gotharman » Sat May 30, 2020 9:51 am
I hope you enjoy!
Great track again!
yorgos_zzz
Post by yorgos_zzz » Sat May 30, 2020 9:58 am
Thank you!
meska
Post by meska » Tue Jun 02, 2020 1:33 am
Idk if it's possible but add modulation possibility on size parameter (specialy on granulator) can be amazing in therme of sonic possibility.
www.meska.fr
yorgos_zzz
Post by yorgos_zzz » Fri Jun 05, 2020 3:46 pm
This is a track made with gotharman's little deformer 3 in conjuction with the, deeply controllable with marvelous results, boss rv-500 reverb.
ld3 manages through a variety of pitch shifting and skipping techniques to present an uncommon, though detailed, sound design.
The track is performed live and presented without editing or corrections.
I hope you enjoy!
gotharman
Post by gotharman » Sat Jun 06, 2020 9:07 am
I hope you enjoy!
Really great noise track! Thanks so much for sharing!
yorgos_zzz
Post by yorgos_zzz » Sat Jun 06, 2020 10:38 am
Thank you!!
yorgos_zzz
Post by yorgos_zzz » Wed Jun 10, 2020 4:29 am
I hope you enjoy!
I consider this track to be vapornoise!
Thank you for putting out such a marvelous device that gives the capability for flawless flow!
gotharman
Post by gotharman » Mon Jun 15, 2020 8:22 am
A new LD3 update are now available:
-Parametric EQ insert effects added
-All sequencer steps on a subtrack can now be offset adjusted with one knob movement
-Position Rotation Modulation added to the Sequencer note tracks
-It is now possible to output one Audio BUS to another Audio BUS.
-A BUS Follower/Envelope OFF position has been added.
-Insert effects input gain can now be adjusted
-When recording an audio track, the BPM of this is now included in the sample name.
-Audio inputs can now be swapped
-Quick Edit Knobs can now be switched off
-Some page names on the BUS pages has been changed, to make it look less cryptic.
You can get it here:
http://www.gotharman.dk/LD3_updates.htm
