It me. I freaking love some FX plugins -- the Valhalla stuff, Twangstrom, Wavesfactory Cassette, Mishby, Lossy, u-he Uhbik, DDMF Magic Death Eye, Gullfoss, CraveEQ, Izotope RX...
As mentioned, there's some CV control possibilities over plugins. I use Bitwig and ES-3/ES-6. Although with most effects I honestly find there's not a lot of benefit of actual CV control rather than just using built-in modulators or Bitwig's modulators.
Feedback is an issue in a DAW. The tightest feedback you can get around a plugin or in Bitwig Grid -- generally requiring some kind of goofy workaround -- is the size of an audio buffer.
I think it's good to have a full-featured delay in Euro though -- something that can sync in fun ways to clocks that might be rhythmic patterns instead of just a straight clock, gracefully handle modulation at audio rate and without slewing the input, do all the crazy tricks with ultra-short delay times while tracking 1V/OCT, and yet is still simple to use and you can just grab a knob and make things happen. For me Mimeophon is that delay.
I also have an FX Aid, because it's quite a useful chameleon, and it's very good at those tight delays and feedback.
E520, because it does some crazy stuff that software doesn't all that well. It's big and expensive and admittedly kind of an indulgence, but it pleases me.
Clouds, because while there are some decent granular synth plugins out there, on the effects side I haven't found anything particularly satisfying in comparison. I like triggering grains from an input...
Phonogene I guess is an effect...? It's hands-on, simple, charmingly lofi without being irritatingly lofi, and can integrate better with modular gear than most loopers which tend to be standalone black boxes.
Also if Rings counts as an effect, which it should: there are a couple of modal resonators in Reaktor that I didn't care for very much, and of course there are some physical modeling synth plugins but there is still nothing that's really like Rings (except Elements, and all the clones and ports of Rings I suppose). It's the module that got me started in Eurorack and I'm going to hang onto it. I don't understand why other companies even bothered to release resonators that don't have an audio input.
I'm also considering getting a BBD again, because even the best software emulations of BBDs are more along the lines of pedals than the noisy, experimental possibilities of an unfilitered BBD that can be pushed beyond its limits.
autopoiesis wrote: ↑Wed Oct 07, 2020 7:02 am
I bought two FX Aids several months back and while I think they sound incredible, I am not crazy about how they respond to modulation (a Spin limitation) nor do I really want to lean on them for their great reverbs because then I'd have to reference a cheat sheet all the time.
That's fair. I don't much like the cheat sheet thing either, and FX Aid is my last module that needs one... but it seems a bit more tolerable than some, maybe because of relative simplicity and some level of consistency among the knob assignments.
But I'll point out, FX Aid does respond well to sample rate reduction CV.
